JDM EF9 Cluster
Old May 29, 2004 | 07:06 AM
kshymkiw83's Avatar
Default JDM EF9 Cluster
I just bought a JDM EF9 cluster. My question is how do i wire it into my 89 Civic DX? Will i have to change any of the cables or is this a direct plug and play? Any help is appreciated, thank you
Old May 29, 2004 | 07:10 AM
crx_88_si's Avatar
you'll need an electric VSS
Old May 29, 2004 | 07:11 AM
kshymkiw83's Avatar
Default Re: (crx_88_si)
should i pull that from a DA integra?
Old May 29, 2004 | 09:16 AM
krazie1's Avatar
BANNED
Default Re: (kshymkiw83)
yes sir???
92-93 I believe is what year they have them or any hydro b series transmission has them
and u will need to re wire the cluster and change the clips
has now four instead of two
if u like to work of your EF then u will have fun but then again if u hate electronics then get a pro to do it
Old May 29, 2004 | 10:33 AM
kshymkiw83's Avatar
Default Re: (krazie1)
Does anyone have a wiring diagram of what goes to what?
Old May 29, 2004 | 01:39 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
TJ's honda's had a diagram up.. and ive successfully pulled it off myself.
now.. don't flame me too hard on the wirring.. it was a complete bitch..
acutally i aksed.. posted.. and go no real help. i belive the majority of the research was at clubsi.. but... when it came down to acutally pulling it off.. other than wiring the electiric VSS.. and connecting that to the ECU.. which in turn goes to the cluster through the harness.. the wirring of the cluster conversion was very stright forward... all you have to do is match the colored wires, thats it.
Old May 31, 2004 | 01:44 AM
kshymkiw83's Avatar
How do you wire in the VSS? Where exatcly will it be placed, and what pin on the ECU does it go to?
Old May 31, 2004 | 04:40 AM
Built B16A's Avatar
12 V power, a ground, and a signal to the ECU..
pin out.. hrmm... http://www.hondaswap.com/forum...29360
B16..
do alittle searching around.
Old May 31, 2004 | 04:46 AM
kshymkiw83's Avatar
Default Re: (Built B16A)
thanks for all the help Built B16A.....i see you have a wiring diagram in your car, is that for the cluster? If so where did you get it?
Old May 31, 2004 | 07:22 AM
Built B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help Built B16A.....i see you have a wiring diagram in your car, is that for the cluster? If so where did you get it?</TD></TR></TABLE>
damnit.. i knew you were going to ask.. lol..
umm.. give me a sec.. where did i find it?
http://www.clubcivicquebec.com....html
a quick google search yielded this one.. wasn't the one i had.. but might help you out.
Old May 31, 2004 | 09:34 AM
shaddr3's Avatar
My link is the best :-p http://www.crxpower.net/phpBB2...=6330
Old May 31, 2004 | 10:17 AM
kshymkiw83's Avatar
Default Re: (shaddr3)
nice link man. For the wire colors and how to install the VSS that is good. Maybe i should sell my EF9 cluster and get a Civic SI one, they look pretty nice.
Old May 31, 2004 | 10:57 AM
I3ackfire's Avatar
Couple of questions...
What is VSS?
ANd on the JDM Cluster, what is that diagram for the car for?
Old May 31, 2004 | 12:33 PM
Built B16A's Avatar
Default Re: (I3ackfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">Couple of questions...
What is VSS?
ANd on the JDM Cluster, what is that diagram for the car for?</TD></TR></TABLE>
Vehical Speed Sensor.. CRX's were driven with a gear, and speedo cable through the firewall to the cluster. and JDM CRX's used elctronic versions of VSS's like the OBD1 setups, with all wires.
diagrams tells you what color wires go to what components of the back of the cluster.. if you don't udnerstand that.. dont' convert your cluster.
Old May 31, 2004 | 01:23 PM
BrianDB1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">yes sir???
youre wrong, 92-93 Integra were still cable driven speedo's and cable clutches.
Old May 31, 2004 | 01:31 PM
krazie1's Avatar
BANNED
good **** bro
way to help them
and well I don't understand how peeps can't just undo the stock clip and use the pins from there instead of using so much bud connectors and extra wires
It just takes some tiem and patience and anyone can really do it
Old May 31, 2004 | 02:44 PM
I3ackfire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">
diagrams tells you what color wires go to what components of the back of the cluster.. if you don't udnerstand that.. dont' convert your cluster. </TD></TR></TABLE>
Oh wait....yup Im not converting my cluster, some other guy is, I was just curious....
Old Jun 1, 2004 | 06:50 AM
Footwork's Avatar
Check sig if anyone is looking for a jdm ef8/9 cluster.
Chrisfrom1986
Mar 25, 2009 02:07 PM
$racer1
Aug 2, 2006 03:28 PM
1989CivicSi
11
Jan 25, 2006 02:24 PM
crexer
10
Aug 30, 2003 10:48 AM
CRX_VTEC
Aug 17, 2003 07:36 PM
