running a wire from the fuse box ??
Old May 29, 2004 | 01:56 AM
andyhoiho's Avatar
Default running a wire from the fuse box ??
HI !!!
i want to add a power mirror and power window to my Hatch, can anyone tell me how to run/wire a wire from the fuse box??
let say if i want to run a wire to the power mirror, and put the fuse into the fuse box, then how can i get/run/wire the wire for the 12volt(+)???
or the wire has already located under the fuse box???
please help me !!!
Thanks !!!!!!
Old May 29, 2004 | 07:58 AM
Simple's Avatar
Default Re: running a wire from the fuse box ?? (andyhoiho)
look at the top-side of the box. there are some un-used horizontal pins you can use a crimp connector and plug right into them.... here's a shitty diagram.
__________
| - - - - - - | < this row here you can run wires from to get your 12v
| Fuses |
| Fuses |
DIRTYsouthBB6
May 3, 2006 07:42 PM
Boarderx192
Dec 5, 2005 07:35 AM
phoshizzle88
Sep 12, 2005 02:27 PM
xstalkrx
Apr 12, 2003 12:21 PM
95gsr
Sep 18, 2001 09:25 AM
