Highest compression possible with b20 stock sleeves?
Old May 28, 2004 | 10:35 PM
allout_eg6's Avatar
Default B20/VTEC highest compression possible on stock sleeves
i'm in the process of putting together a cheap b20/vtec build i am going for pistons and rods for the block but i want it daily driven and knowing that the b20 sleeves are a bit weak just wondering whats the highest i can go with stock sleeves this motor is going ALL MOTOR.
Modified by allout_eg6 at 11:57 PM 5/29/2004
Old May 29, 2004 | 08:16 AM
SkRiBLaH's Avatar
Default Re: Highest compression possible with b20 stock sleeves? (allout_eg6)
you dont really need more than 12:1
so i would say 11.5:1
Old May 29, 2004 | 02:56 PM
allout_eg6's Avatar
Default Re: Highest compression possible with b20 stock sleeves? (SkRiBLaH)
yeah thats what i was thinking 11.5:1 on stock sleeves but just wondering is there anyone actually running that right now with stock sleeves?
Old May 30, 2004 | 05:52 PM
allout_eg6's Avatar
anyone? before i go ahead and do this
Old May 30, 2004 | 09:20 PM
11sec CR-X's Avatar
I run 84.5 mm 12.5:1 comp Wisecos. 93 octane chipped p28. No tuning been running like a champ for 2 years.
Old May 30, 2004 | 10:15 PM
DEVIOUS_EG*'s Avatar
Default Re: B20/VTEC highest compression possible on stock sleeves (allout_eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">you dont really need more than 12:1
Old Jun 1, 2004 | 07:26 PM
B20VTECALLMOTOR's Avatar
I AM RUNNING 11.5.1 AND NO PROBLEMS
Old Jun 1, 2004 | 08:10 PM
HotRodTeg's Avatar
Default Re: B20/VTEC highest compression possible on stock sleeves (B20VTECALLMOTOR)
The highedt we have gone was 12.5:1. And i wouldent go any higher. I say the max i would do is 12.1.
Old Jun 1, 2004 | 08:14 PM
dfoxengr's Avatar
hmm???
anyways. im sure you could get away with high 13 compression.
Old Jun 2, 2004 | 02:10 PM
allout_eg6's Avatar
Default Re: B20/VTEC highest compression possible on stock sleeves (CrazyCompression)
so you had no problems with the sleeves splitting and was this daily driven?
Old Jun 2, 2004 | 02:55 PM
Ditdogs's Avatar
NA you dont have to worry about the block, you can go 13:1 crp but only thing holding you back is that you want to keep it streetable, and with 13:1 your going to have to be on race gas every time. 11:5:1 you can use 93 oct and be fine, so the best cpr for streetable on reg gas is 11:5:1
1320DRAGWORKX
17
Jun 9, 2007 02:48 PM
blackassasin95
Nov 4, 2004 10:38 PM
99EletronblueSI
Oct 20, 2004 07:46 AM
boost_addict
Mar 5, 2004 03:23 PM
joacim
Feb 3, 2004 04:00 PM
