What is the advantage...
I see no dvantage at all. I tried running them for a while, but went back to stock b/c I saw no difference & I figure in this case, the breather hose is there for a reason.
The breather is just to provide a vent so pressure doesnt build in the upper manifold area/valve cover. You will see no performance increases either way. Easier to just leave it like its intended so you dont get oil puddles on your valve cover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvbuckeye »</TD></TR><TR><TD CLASS="quote">so it's better for that oil to go into your intake?
Oil will not go into your intake, trust me. Honda would not design a car to do that.
Yes, its designed with the little bypass pipe to float the extra (if any) oil back to the intake. You gonna sit and tell me that Honda designed ALL their engines incorrectly? Naw, I dont think so.
Im saying it doesnt offer perfomance increases, so it makes no sense. The amount of oil is negligible that actually makes it back to the intake, unless of course you have bad valve seals or seats...then you will have a lot more blow by.
Its emissions. oil vapors build up in the valve cover, so instead of venting them into the atmosphere they routed it back through the intake tube to be burnt up. Putting the filter on will simply keep your intake mani a little cleaner.
none of this is correct at all. it's all part of the crankcase ventalation system.
The PVC is what puts the vapor back into the intake manifold. That tube that is on the valve cover going to the intake tube is an air inlet, what you remove you have to replace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Keebler" »</TD></TR><TR><TD CLASS="quote">The breather is just to provide a vent so pressure doesnt build in the upper manifold area/valve cover</TD></TR></TABLE>
Partly correct on the emissions, its to vent pressure also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "blah13" »</TD></TR><TR><TD CLASS="quote">Its emissions. oil vapors build up in the valve cover, so instead of venting them into the atmosphere they routed it back through the intake tube to be burnt up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "crx_88_si" »</TD></TR><TR><TD CLASS="quote">...none of this is correct at all. it's all part of the crankcase ventalation system.</TD></TR></TABLE>
Please read before you discount what others write.
I already stated it was part of a vent system for pressurization.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">none of this is correct at all. it's all part of the crankcase ventalation system.
The PVC is what puts the vapor back into the intake manifold. That tube that is on the valve cover going to the intake tube is an air inlet, what you remove you have to replace.</TD></TR></TABLE>
Ding,ding,ding.......we have a winner!!!!!!!!
