New Syncro's?
Old May 28, 2004 | 09:57 PM
endlessdv's Avatar
Default New Syncro's?
Im running the y1 LSD cable transmission on my car. Ive tried the GM synthetic stuff and I guess it didnt work for me. Anyone know how much new syncros go for and where I could buy them. Its either that or get a LS tranny to replace it.
Old May 28, 2004 | 10:16 PM
EL Vap133's Avatar
Default Re: New Syncro's? (siamturbo)
How long ago did you put it in? I had the same exact tranny on my ride, sold it to my friend and he added the GM syncromesh and the grinds are gone!
Old May 28, 2004 | 10:41 PM
DJ_SaNdOz's Avatar
did you purchase the standard gm fluid, or the friction modefied? In my experience the FM stuff works wonders. If you do decide to try another route, synchro replacement is expensive unless you can DIY, if not, then I'd just buy a used tranny.
Old May 29, 2004 | 10:11 AM
endlessdv's Avatar
Default Re: New Syncro's? (DJ_SaNdOz)
The one I used wasnt FRICTION MODIFIED.. Which was part #12345349.. But it was the GM Synthetic.. Should I give this stuff another try with the friction modified stuff?
Does Penzoil Have the friction modified stuff?
Old May 29, 2004 | 03:04 PM
Op IVY Si's Avatar
synchros aren't that much... I am guessing its 3rd gear your having problems with, its like $250 for the 3rd - 4th gear synchro. If you go to Honda or any shop to get it done they are going to charge you A LOT to take the transmission off.
Old May 29, 2004 | 09:39 PM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siamturbo &raquo;</TD></TR><TR><TD CLASS="quote">The one I used wasnt FRICTION MODIFIED.. Which was part #12345349.. But it was the GM Synthetic.. Should I give this stuff another try with the friction modified stuff?
Does Penzoil Have the friction modified stuff?</TD></TR></TABLE>
I would try the FM before you give up........
Old May 29, 2004 | 10:35 PM
AzCivic1.6's Avatar
get the good stuff and report back.
MtnCRX
Apr 4, 2012 06:31 PM
RS'R'
Jan 3, 2007 05:44 PM
Libertariat
14
Oct 18, 2006 05:48 PM
PatrickGSR94
Oct 14, 2003 03:01 PM
DeDonDeRosa
Apr 20, 2003 06:13 PM
