'98+ ABS system the same between base Integra and ITR?
Old May 28, 2004 | 08:46 PM
Jonathan_ED3's Avatar
Default '98+ ABS system the same between base Integra and ITR?
I know in '98+, all the Integras (with ABS at least) have the 1" MC etc.
My question is this:
Is there a difference in the actual ABS sytem itself? Or is it the same between the base and the ITR?
Reason I ask is because I have the entire ABS system out of a '98 GSR along with the MC and BB, but I'm going with ITR brakes all around as opposed to the GSR brakes.
I just don't want to run into any problems.
Any clarity on this matter will be greatly appreciated. Maybe I'm overanalyzing the situation.
Old May 28, 2004 | 08:55 PM
ZygSpeed's Avatar
Default Re: '98+ ABS system the same between base Integra and ITR? (Jonathan_EH)
The ABS for the ITR was supposed to be an "advanced" version above and beyond the system in the GSR ar the time.
That being said, and given the facts of your post above, there should not be any practical problem in using the larger ITR brakes with the GSR's ABS.
Old May 28, 2004 | 09:12 PM
Thanks for the reply.
It is my understanding that the 'advanced' (not quoting you directly, as I've seen this word used many times in regards to the ITR) ABS system came out for the ITR in '96 (or whenever I the ITR came out...I think it was '96) while the USDM GSR still had the heavier, bulkier, less reliable older system.
Then this 'new' system was also implemented into the GSR when the ITR came stateside or shortly thereafter; maybe to keep things a little more simple.
I've yet to confirm or disprove any of this, but I'm glad to read your thoughts on the subject as rather reassuring.
Old May 28, 2004 | 09:23 PM
ZygSpeed's Avatar
Default Re: (Jonathan_EH)
I'd suspect this could be cleared up with some pics.
I can take some of a 97 ITR's ABS tomorrow.
Also, there were some graphs of the newer ABS implementation in the 97 Helms supplement.
Old May 28, 2004 | 09:41 PM
Good thinking.
All of the following are '98 GSR.
You may not be able to get a picture of your lines along the firewall, but it may be a decent enough reference to check against yours.
Old May 28, 2004 | 09:44 PM
ZygSpeed's Avatar
Hehe ... OK, give me a few min (its 1:45 AM here) and I'll go out to the car and take a pic or two.
Old May 28, 2004 | 09:53 PM
Awesome!
It's going on 1am here.
Old May 28, 2004 | 10:00 PM
ZygSpeed's Avatar
Looks like the actual ABS actuators are pretty much the same.
This is from my 97 ITR.
Old May 28, 2004 | 10:11 PM
Thank you very much for the help!
Since the MC/BB are the same (1") and judging by your pictures, I reckon it's fairly safe to assume the 98+ systems are the same across the board, while the pre '98 non ITR's have the less desirable system.
Thank you very much for the pictures.
Old May 28, 2004 | 10:13 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">Thank you very much for the pictures.</TD></TR></TABLE>
Glad to help.
Black R
Oct 24, 2012 06:22 AM
DC2 to AP2
Jul 8, 2004 10:48 AM
mikeweb
Feb 24, 2004 12:27 AM
Boostage
Dec 10, 2003 04:25 PM
yaksplat
Aug 23, 2001 08:42 AM
