What would you do? Time for a swap?
Old May 28, 2004 | 04:28 PM
B2FiNiTY's Avatar
Default What would you do? Time for a swap?
Water pump just started leaking now.
The car currently has 206k on the stock motor/tranny but it runs great. Gets good mileage, doesn't smoke, burn oil etc. I haven't checked the compression but the car is definately not as responsive as my previous CRX with 155k on it.
Should I spend the $100+ dollars on replacing the water pump or
1) swap in a d-series (d16y7, d16z6) - save money
2) swap in a b-series (b18b) - take the chance to do what I wanted
I already picked up HAsport mounts and shift linkage awhile back.
NOTE: I do not want a b16, not enough tq, and the b18c1 is too much money.
Old May 28, 2004 | 04:31 PM
CrX-To-Tha-Max-v2.0's Avatar
Default Re: What would you do? Time for a swap? (B2FiNiTY)
If you wanna spend a little dough, B series is what i would do for sure. Must better platform to work off of, and not bad gas mileage.
Old May 28, 2004 | 04:45 PM
kylefakesi-r's Avatar
Default Re: What would you do? Time for a swap? (CrX-To-Tha-Max-v2.0)
honestly...**** it. get a da integra or something for cheap like that.
if you really love the crx do the b swap-you will love it.
if you are not entirely attached to the car but would like a little money out of it...fix it and unload it or do teh dseries swap, drive it for a while, and then unload it.
not saying that getting rid of the car as a whole is the best solution but i have seen lots of crx's and hatches lately selling for around 2500 with bseries engines already in them but not much else done. i would just pick up someone else's frustration, correct the things they have done wrong and live life with a few less scraped knuckles than i would have had if i swapped on a 200k+ car.
Old May 28, 2004 | 04:48 PM
B2FiNiTY's Avatar
Default Re: What would you do? Time for a swap? (kylefakesi-r)
There is nothing wrong with the car other than now needing to replace the water pump.
Interior and exterior is clean as it can be for a car this age. IMMACULATE, I would even venture to say.
Old May 28, 2004 | 04:55 PM
shove a b in it and eventually go low boost-since the chassis is clean. i am used to rust and seized bolts up here in wisconsin...anything past 140k isn't worth working on.
Old May 28, 2004 | 05:00 PM
infinatenexus's Avatar
Option 1
Old May 28, 2004 | 05:01 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">There is nothing wrong with the car other than now needing to replace the water pump.
If car is imacculate, do the water pump/ T-belt and be done with it
I say "lets save as many pristine stock CRX's as we can." LOL
An immaculate original cult car has a better re-sale than a modded car does.
As for me, my D15B2 has a bad water pump, an oil leak, low compression and low oil pressure. But the rest of the car is in VG shape save for a little rust. So I'm torn as to what to do. B17 or junkyard D15B2 ?
But in your case.... fix it and sell it. Buy a terminal case car to do the swap.
Save the unwanted cars from the junkyard.
Like they say on the speed network...."Don't crush 'em.......restore 'em."
Just my .02 cents
Old May 28, 2004 | 05:48 PM
B2FiNiTY's Avatar
Default Re: What would you do? Time for a swap? (4crx4me)
No way I would ever sell this thing.
B-series seems the way to go right now.
Timing belt and water pump is over $100 for oem parts, which is only what I use.
Old May 28, 2004 | 05:53 PM
nor.cal's Avatar
Do a semi built d and turbo the bitch.
Old May 28, 2004 | 06:02 PM
SMZ GSR's Avatar
200k+ Club y0
Either choice of swaps would be nice. I'd say go with D-series since it's your beater and you got another car for track
Old May 28, 2004 | 06:11 PM
B2FiNiTY's Avatar
Default Re: What would you do? Time for a swap? (SMZ GSR)
More and more, I'm thinking about just replacing the pump only, inspecting the belt and change if needed.
Old May 28, 2004 | 06:13 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">More and more, I'm thinking about just replacing the pump only, inspecting the belt and change if needed. </TD></TR></TABLE>
Keep it STOCK, I approve.
Old May 28, 2004 | 06:19 PM
SMZ GSR's Avatar
Try and catch me
I'm assuming I'll hit at least 300k before mine goes at. (Currently at 251k in my DX and running strong)
Old May 28, 2004 | 06:20 PM
B2FiNiTY's Avatar
I must...catch... j000000!
Old May 28, 2004 | 06:47 PM
Nature's Renewal's Avatar
210+k miles on stock d16a6 and doesn't burn anything, great compression, 30+mpg...gonna go turbo soon. So you know where my opinion lies.
Old May 28, 2004 | 10:36 PM
B2FiNiTY's Avatar
Default Re: What would you do? Time for a swap? (krskid)
Sounds like my motor I've decided to keep this motor going for a bit longer
I also have a 89 si
Old May 28, 2004 | 10:38 PM
EL Vap133's Avatar
Might as well go B18B, great engine, got it in my Teg.
Old May 29, 2004 | 09:13 AM
StupidSlowRSX's Avatar
Default Re: What would you do? Time for a swap? (EL Vap133)
for torque, im actually really happy with the zc..
light and holds its own
Old May 29, 2004 | 09:57 AM
crx_88_si's Avatar
replace the belt too. it's called preventative maintenance.
HondaCRZY
Dec 13, 2014 04:32 PM
matt j
Sep 15, 2008 12:02 PM
Neptronix
26
May 30, 2007 07:06 PM
elnoyl
May 22, 2005 08:50 AM
The Alchemist...
11
Apr 26, 2005 12:12 PM
