Anyone know the correct way to mount a 4pt harness into a EJ1?
Old May 28, 2004 | 03:37 PM
goodfella732's Avatar
Default Anyone know the correct way to mount a 4pt harness into a EJ1?
I wanna buy the Sparco Clubman 4PT Bolt in. I have a Sprint seat in the car now. Whats the correct way to mount the harness? Do I use the 2 driver's seatbelt points and the 2 in the rear?
Old May 28, 2004 | 03:49 PM
IWearMyKswiss's Avatar
New User
Default Re: Anyone know the correct way to mount a 4pt harness into a EJ1? (goodfella732)
the correct way is to mount the harness to a harness bar that is in a car with a complete roll cage
Old May 28, 2004 | 04:47 PM
bbarbulo's Avatar
well, the lap belts are too long, so I recommend moving the mounting points way back into the rear footwell, and using reinforcement plates from under the car to mount it. for the rear, you can use the rear deck with reinforcements from underneath, or the rear seatbelt mounting point. They key is not the have the rear straps anywhere close to vertical. In an accident, if your spine and the rear straps are ever at the same angle, it'll crush your spine.
Old May 28, 2004 | 05:15 PM
99blackcivicSi's Avatar
Default Re: (bbarbulo)
The correct way to mount a a 4 point or a 5 point is to mount it in conjuction w/ a cage. I will not give out advice that puts your life in danger even more in the case of a rollover.
Old May 29, 2004 | 08:04 AM
Default Re: (99blackcivicSi)
Do I need a cage to use the Sparco harness bar also?
Old May 29, 2004 | 10:52 AM
slammed_93_hatch's Avatar
Default Re: (goodfella732)
no you don't but without a roll bar/cage if you roll you will be stuck in that position and not be able to get out of the way of the colapsing roof. while ur stock seat belt alows you to get out of the way of something like that. a 4 or 5 point harness will hold you right there untill you head is a gummy bear and your dead.
Old May 29, 2004 | 12:42 PM
C_Civic's Avatar
Default Re: (slammed_93_hatch)
Not that im against anything i'd rather have a roll cage and then my 4 or 5 points...but wat are the chances of a rollover in our little hondas for street driving?
Old May 29, 2004 | 01:04 PM
Default Re: (C_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Not that im against anything i'd rather have a roll cage and then my 4 or 5 points...but wat are the chances of a rollover in our little hondas for street driving?
uhhh if you drive like an *** it will rollover, run off the road, over correcting millions of possibilitys for a rollover in ANYTHING do it right the first time don't be a ******* moron and only use some saftey equipment and not use the rest of the stuff it is sopposed to be in conjunction with.
Old May 29, 2004 | 04:16 PM
Anyone suggest a good company that sells cages then??
Old May 30, 2004 | 06:27 PM
C_Civic's Avatar
Old May 30, 2004 | 07:25 PM
autopower, kirk use google there are alot of places that sell them
Old Jun 5, 2004 | 11:38 AM
C_Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
uhhh if you drive like an *** it will rollover.</TD></TR></TABLE>
Old Jun 5, 2004 | 02:43 PM
twincam03's Avatar
if youre still looking
harness bar made by Sparco, if you dont want a cage...
http://sparcousa.com/harness_bars.asp
Old Jun 5, 2004 | 03:10 PM
egizzle8
Guest
Posts: n/a
"I really am, as dumb as I look"
You explained yourself already.
1. Buy cage
2. Buy harness
3. Install cage
4. take harness and tie into a noose
5. Loop harness around neck
6. Start car shift into gear and stomp on gas pedal.
7. Let go of steering wheel and slam and brake pedal.
Hah hah. Just kidding. If you still want a good harness but don't want a cage then buy a three point harness and there's more adj. , but what do you need a 4 or 5 point harness for anyways?
Old Jun 5, 2004 | 03:18 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Civic &raquo;</TD></TR><TR><TD CLASS="quote">but wat are the chances of a rollover in our little hondas for street driving?
what would you like in the chance of a rollover? a 25% chance of living, or a 2% chance?
with a harness and no rollbar if you roll, you will probably die.
if you want a harness, you need to get a rollbar w/ harness bar.
Modified by Kamin at 7:54 PM 6/5/2004
Old Jun 5, 2004 | 06:42 PM
C_Civic's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
if you want a harness, you need to get a rollbar w/ harness bar.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Not that im against anything i'd rather have a roll cage and then my 4 or 5 points</TD></TR></TABLE>
Uhh hmmm....think about it!
Old Jun 6, 2004 | 09:20 AM
Default Re: (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">"I really am, as dumb as I look"
1. Buy cage
2. Buy harness
3. Install cage
Hah hah. Just kidding. If you still want a good harness but don't want a cage then buy a three point harness and there's more adj. , but what do you need a 4 or 5 point harness for anyways? </TD></TR></TABLE>
If I knew all that before I wouldn't have ask dumbass. I didn't know you needed a cage.
Old Jun 6, 2004 | 11:07 AM
upgraded's Avatar
uhhh if you drive like an *** it will rollover, run off the road, over correcting millions of possibilitys for a rollover in ANYTHING do it right the first time don't be a ******* moron and only use some saftey equipment and not use the rest of the stuff it is sopposed to be in conjunction with.</TD></TR></TABLE>
Man, for someone not wanting to give advice you sure don't have a problem throwing you opinion around smacking evryone in the ***** with it. Why not keep it to yourslef or atleast use a little tact when expressing it. You might not drive like an ******* but you sure seemed to act like one.
HypL
May 1, 2012 07:57 AM
slprrex
Jan 1, 2007 03:41 PM
Gant
34
Jul 20, 2006 09:32 AM
ITRmike98
Oct 28, 2002 07:32 PM
