how can i get overspray off my tint?
Old May 28, 2004 | 03:33 PM
Kwayzie's Avatar
Default how can i get overspray off my tint?
Old May 28, 2004 | 03:46 PM
Quad-Damag's Avatar
Default Re: how can i get overspray off my tint? (Kwayzie)
clay bar, gets off alot of overspray it's good ****, just takes HELLA days to get off
Old May 28, 2004 | 04:48 PM
I Shot 50 Cent's Avatar
How did you manage overspray on the INSIDE of the glass? But yeah, clay ususally works wonders, not sure about its effect on window film, it may smear onto it.
Old May 28, 2004 | 05:48 PM
Quad-Damag's Avatar
Default Re: (R81DC2LS)
razor blade, BE VERY CAREfull not to take the tint off, that will be mad hard
Old May 28, 2004 | 06:00 PM
Lil Noodle's Avatar
I used a plastic razor blade and wet the window with windex it worked pretty well .. didn't scratch the tint at all
Old May 28, 2004 | 06:22 PM
92DSeries's Avatar
Default Re: how can i get overspray off my tint? (Lil Noodle)
^ i think windex as amonia in it..which helps in the process of removing tint, so be very carefull not to scratch the tint if u choose to use windex...cause then ull end up getting a bubble where the tint has removed itself from the glass
i might suggest using a mild soapy water solution instead of the windex
Old May 28, 2004 | 06:41 PM
Kwayzie's Avatar
thank you all for your tips, im going to give it a try
JDMJUNKIEMONKIE
15
Nov 6, 2009 06:16 PM
1993ludevtec
Mar 22, 2004 03:19 PM
JdmLsPwr425
Mar 10, 2004 07:34 PM
quik2kSi
Jan 3, 2004 11:32 PM
IdotheSHOCKER
Jun 1, 2002 05:00 AM
