si head vs. gsr
Old May 28, 2004 | 03:02 PM
rev2ninetyper's Avatar
Default si head vs. gsr
ive heard but always wondered if its true that the 00' factory si head flows better than the gsr head. is there any proof of this if it is true? cuz machine works expensive.
95' h22a accord/ 94 gsr
Old May 28, 2004 | 03:05 PM
Kendall's Avatar
From the factory, there aren't any significant flow differences, in fact there are a few flow charts in the all motor forum which prove this. The only notable performance difference is the combustion chamber design which on the GSR is a bit more of a "pent-roof" design as compared to the Si's more "hemispherical" design, thus resulting in slightly different combustion characteristics, different quench, and slightly less combustion chamber volume in the GSR head thus raising compression.
Old May 28, 2004 | 03:09 PM
Default Re: (Kendall)
so basically the "dome" chamber of the heads is the only real difference? the ports arent larger or less restrictive?
Old May 28, 2004 | 03:25 PM
Kendall's Avatar
There are port differences, but flow charts have shown that there isn't any notable difference in airflow between the two heads.
Old May 30, 2004 | 06:21 PM
radteg's Avatar
the b16 has very good air flow for stock but the cams and valves are what limit it compaired to the gs-r head.i've always heard that if u port and polish the IM on a b16 and some mild P&P on the b16 it's just as good as a itr head.but thats what i hear, the gs-r is always better out of the box though
Old May 30, 2004 | 06:23 PM
radteg's Avatar
http://www.importreview.com/re....html
vtexas936
13
Nov 20, 2011 06:22 PM
jdmstyleEJ6
39
Apr 17, 2010 07:03 PM
dcforgod
May 14, 2008 05:07 AM
fliptout
Apr 4, 2007 07:39 PM
blk007
Jul 14, 2005 10:20 AM
