dot 4 fluid safe for 4th gen?
As long as its not silicone based, you'll be fine. Silicone fluid tends to get bubbles in the line when the abs goes off. Not to mention that water doesn't mix with the silicone causing it to pool in concentrated areas promoting rust inside the brake lines.
redDAinteg
Jan 4, 2007 01:53 PM
BiGcAmBoDiAnSaUsAgE
Nov 20, 2006 11:42 AM
