help i have 3 codes throwing at me... i need help to fix them...
Old May 28, 2004 | 11:36 AM
al3e's Avatar
Default help i have 3 codes throwing at me... i need help to fix them...
right now i have
10 IAT - intake air temperature sensor
14 IAC (EACV) - idle air control valve
21 VTEC spool solenoid valve
I don't know how to fix any of them... maybe i need to switch them around? or get new ones? or what? yes i have searched, didnt find anything that helped....
Old May 28, 2004 | 12:14 PM
julio1998's Avatar
Default Re: help i have 3 codes throwing at me... i need help to fix them... (al3e)
code 10 is sensor on air inlet tube black.code 14 is sensor on manifold. code 21 is vtec its on the side of head green plug check connection and sensor
Old May 28, 2004 | 12:27 PM
al3e's Avatar
Default Re: help i have 3 codes throwing at me... i need help to fix them... (julio1998)
holy hell! thank you! i knew that...thanks tho..
i need to find out how to fix them....
Old May 29, 2004 | 06:57 AM
al3e's Avatar
...cmon...anyone..???? how do i fix these...?? get new sensors?
Old May 29, 2004 | 07:09 AM
SprayinCX's Avatar
have you tired switching the iac and the iat around? you could have them backwards. as far as the vtec solenoid you can take a wire and hook it to your battery and then touch it to the wire that comes from the solenoid itself and see if clicks or not. if it does then it is good if not then it is burnt up.
Old May 29, 2004 | 04:33 PM
al3e's Avatar
Default Re: help i have 3 codes throwing at me... i need help to fix them... (SprayinCX)
nm
Modified by al3e at 5:48 PM 5/29/2004
Old May 30, 2004 | 11:07 AM
al3e's Avatar
Old May 30, 2004 | 11:14 AM
TurboBumblBee's Avatar
why are you throwing the codes? u just do a motor swap? need more info.. what ecu, what motor? things like this..
Old May 30, 2004 | 11:16 AM
al3e's Avatar
Default Re: help i have 3 codes throwing at me... i need help to fix them... (Boostfedb18c1)
yeah i just did a z6 swap in my 93 cx..... ecu = p28 and harness = z6
y-49
Jun 23, 2007 05:05 PM
beedoublejay
Aug 21, 2005 03:28 PM
Red_Si
23
Jan 24, 2004 11:04 AM
memphiss13
Jan 19, 2002 04:15 PM
