Does anyone know what THIS IS??
Does anyone know what these 3 things are? Here are a pictures of them, they are in back of the passenger headlight and I traced the wire back and it was plugged into the ac blower under the dash. Anyone??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic »</TD></TR><TR><TD CLASS="quote">they are relays</TD></TR></TABLE>
No ****. But I think he means what are they for. As for me I think one is for your fan and one other is for the A/C fan, don't have a clue on the third one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorCRX161 »</TD></TR><TR><TD CLASS="quote">I want to pull them out, you think I can and my radiator fan will still work??</TD></TR></TABLE>
Nope, leave them in they are there for a purpose.
Unplug them and try all your accessories and see what turns on and what doesn't.
Maybe a hedlight relay?
Maybe a horn relay?
Maybe a horn relay?
Good Helm's pic!
Lookig back at the posters pic, is there anything attched to the metal bracket that is on the right side of your pic? I can't see then end of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">helms is a wonderful thing.
SURE IS
SURE IS
why remove them if they arent messing anything up ... I say if its broken replace it or fix it..if not leave it alone...I can see removing it, if its in the way of something else and its useless like in this case but think of it this way .. do you think you'll need em later? if so i say keep em. .if not !@# $ it! hehe. I can see why you want to remove em , as i prob would want to as well, but then just make sure you're not going to need it in the long run. I dont make sense anymore i'll just shut up!
they are also grounds. my pass side headlight was dim, so i cleaned the connection of those plugs to the body and the headlights were bright again.
schumi
Sep 15, 2007 01:17 PM
