anybody think i could get this 00 si greddy kit to fit in my rex?
Old May 28, 2004 | 10:18 AM
slowpokesi's Avatar
Default anybody think i could get this 00 si greddy kit to fit in my rex?
i know i would have to relocate the battery, but from the looks of this kit, i think i could get it all to work, as long as the radiator hose wasnt in the way, what do u think.
Old May 28, 2004 | 10:26 AM
90civichbsi's Avatar
Default Re: anybody think i could get this 00 si greddy kit to fit in my rex? (slowpokesi)
you may have to make custom hotside intercooler pipes, compared to the 00 si's we have a crossmember in the way. other than that and battery relocation, it looks like it would you may have to get slimfans or switch em to the front of the radiator too
Old May 28, 2004 | 10:29 AM
slowpokesi's Avatar
Default Re: anybody think i could get this 00 si greddy kit to fit in my rex? (90civichbsi)
i planned to swap in a 92 civic radiator, possibly a fluidyne, and use a pusher fan on the front of the radiator, since i wont have ac anymore i planned to take out the condensor as well. i think that could free up some room
Old May 28, 2004 | 10:47 AM
96-EJ6 B18C's Avatar
Just re-do the charge pipe to fit the EF and you'll be set
Old May 28, 2004 | 11:43 AM
UNDER PRESSURE's Avatar
Default Re: anybody think i could get this 00 si greddy kit to fit in my rex? (96-EJ6 B18C)
I accually had that set up on my rex. All I had to do is get some slim fans and fab up the charge pipe that goes from the turbo to the intercooler. the rest of the stuff bolted on without a hastle.
Old May 28, 2004 | 11:49 AM
slowpokesi's Avatar
Default Re: anybody think i could get this 00 si greddy kit to fit in my rex? (UNDER PRESSURE)
how did the kit work for you, how much power did you make on the dyno @ what psi.
what did you do about the map sensor
did you dp clear the xmember,
did you run a inline fuelpump or did u go with an intank
Modified by slowpokesi at 3:00 PM 5/28/2004
Old May 28, 2004 | 11:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">how did the kit work for you, how much power did you make on the dyno @ what psi.
what did you do about the map sensor</TD></TR></TABLE>
It worked good, pulled like a **** very fast spool up. I made like 205 whp and 200lb fttq. @6 psi, it ran a 13.8 @ 105mph on **** tires. I would easily burn first through the middle of fourth gear, thus the shitty times. No traction= make sure you get some slicks.
Old May 28, 2004 | 12:01 PM
slowpokesi's Avatar
did you have a baseline, right now i put down 156 whp im trying to figure out how much i will gain.
what did you do about fuel and such, i looked at the picture of ur setup in your for sale thread and didnt see any fmu or anything.
Old May 28, 2004 | 12:19 PM
I ran 450's and a vafc with a 255lph fuel pump and a B&M fuel pressure regulator.
Old May 28, 2004 | 03:27 PM
i dont think you would need a 92 radiator if you put slimfans on the front, the greddy turbo doesnt stick that far out from the block. you could prolly keep a/c too if ya wanted. but then again.. the more room the easier
Old May 28, 2004 | 06:45 PM
slowpokesi's Avatar
sup, didnt recognize you with the new avatar. did you ever get your turbo project off the ground.
i plan on buying this kit now but not installing it for a while, there are a few extras that i need that i cant afford just yet. but eventually i would like to upgrade to a fluidyne, and stuff.
im either going to get this or a revhard. This kit has its advantages, but so does the revhard.
we will see what happens next week.
ILUVMYEM1
Jun 26, 2006 09:39 AM
jsteezy1290
Oct 20, 2005 04:22 PM
gsrhunny
Jan 7, 2004 09:39 AM
turbojdm521
Jun 13, 2003 08:59 PM
slowpokesi
Oct 27, 2002 09:57 PM
