D16a1?????
Old May 28, 2004 | 07:12 AM
GReatEDDY's Avatar
Default D16a1?????
A D16a1 wont swap into a 88-91? Ive got a EE4 88awd wagon with a blown motor and Im looking for options. Id like to buy a JDM zc but 400 for the motor and 300 to ship doesnt seem economical to spend 75% fo the motor cost on shipping. Anybody got any Ideas. I also have a D16z but since mine is a 88 there is the Clutch problem with the difference in spines. ummmm what to do?
Old May 28, 2004 | 07:15 AM
90SICRX's Avatar
Default Re: D16a1????? (GReatEDDY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReatEDDY &raquo;</TD></TR><TR><TD CLASS="quote">A D16a1 wont swap into a 88-91? Ive got a EE4 88awd wagon with a blown motor and Im looking for options. Id like to buy a JDM zc but 400 for the motor and 300 to ship doesnt seem economical to spend 75% fo the motor cost on shipping. Anybody got any Ideas. I also have a D16z but since mine is a 88 there is the Clutch problem with the difference in spines. ummmm what to do?</TD></TR></TABLE>
$300 for shipping?! where are you shipping it from the moon?
Old May 28, 2004 | 07:18 AM
GReatEDDY's Avatar
Default Re: D16a1????? (90SICRX)
Where do you suggest? East Coast
Old May 28, 2004 | 07:21 AM
hatchblack's Avatar
the splines on the clutch shouldn't matter as long as you keep the 88 tranny - i have the z6 in my 89 si. i am using the si tranny, z6 block and a clutch and flywheel from a 90-up civic. i know the 88 has a different spline count, but the only thing that goes through that clutch is the shaft from the tranny. i would assume you were going to be keeping the awd tranny to keep the awd on that civic, right? then the z6 motor will bolt up to that tranny and you can just use the 88 clutch and flywheel - that flywheel will also fit the z6 block - it's just smaller. so if you have a z6 motor sitting around, wire it up and throw it in!
Old May 28, 2004 | 07:24 AM
90SICRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReatEDDY &raquo;</TD></TR><TR><TD CLASS="quote">Where do you suggest? East Coast</TD></TR></TABLE>
shipping from the east coast? I'm getting my engine from west coast and it's only 150 for shipping
GReatEDDY's Avatar
Default Re: D16a1????? (hatchblack)
Is there any ECU that will work with the harness already in the Wagon or Do have to cut up a 92-95 harness and hardwire into the wagons?
Old May 28, 2004 | 07:30 AM
hatchblack's Avatar
i used the boomslang obd0-1 harness and wired in like 4 wires, an 02 sensor, and the distributor. had to extend a couple other plugs, no big deal. did the whole motor rebuild, engine swap, wiring, and even added msd to the car in about 3 days - it was very easy and simple stuff.
Old May 28, 2004 | 07:34 AM
kyle h.'s Avatar
get a sohc zc.
B18CEJ205
Aug 20, 2008 08:12 AM
CRX MASE
Aug 17, 2004 08:48 PM
scratchy
10
Jul 27, 2004 01:38 PM
kyle h.
Mar 24, 2003 11:58 AM
DanielLaruso
12
Jan 17, 2003 11:37 AM
