FAILED emission's again.. but getting closer
1st TIME i went to emissions i got these readings
NOx--1006--197 PASS
HC--132--408 <U>FAIL</U>
CO%--.73--9.17 <U>FAIL</U>
Did some to0ning on a dyno, and made me a new chip and this is what i got 2nd time around at EMISSIONs
NOx--1006--1044 <U>FAIL</U>
HC--132--282 <U>FAIL</U>
CO%--0.73--3.81 <U>FAIL</U>
My NOx went up 847pt's WTF
... Help, if anyone can help me to0n the p28 alil better so that i can atleast pass emission please letme know.. i have both .bins that i used.. any and all advise or suggestings would be much apprecaited!!
Modified by patastinky at 9:08 AM 5/28/2004
NOx--1006--197 PASS
Damn, that sux. I passed with my 170K mile H23 with Carsound high flow cat and Thermal exhaust. Not that this is supposed to make you feel any better.
lol I passed my emmisions without a CAT... lol
Anyways your prolly not passing because your engine not running clean enough... Try to make sure everything is in tip top shape before you go back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saki »</TD></TR><TR><TD CLASS="quote">lol I passed my emmisions without a CAT... lol Anyways your prolly not passing because your engine not running clean enough... Try to make sure everything is in tip top shape before you go back </TD></TR></TABLE>
w3rd!!1! that's the point of this post
went on a dyno and put down some good numbers and i had a pretty stable a/f reading.. but still not good enough for emissions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex »</TD></TR><TR><TD CLASS="quote">How old is your catalytic converter?</TD></TR></TABLE>
it's a CARSOUND CAT and it's 2months old at most
guess ill have to put some 87octane in it for emission, and retard my timing like a mother ******!!1!
went on a dyno and put down some good numbers and i had a pretty stable a/f reading.. but still not good enough for emissions <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex »</TD></TR><TR><TD CLASS="quote">How old is your catalytic converter?</TD></TR></TABLE>
I don't know if it will help, but the shop I use told me to put in about 8% methanol. I passed the last two years by only 1 ppm on the low speed Hydrocarbon emissions. The methanol supposedly helps on emissions. You should be able to get it from any speed shop for around $8.00 a gallon. By the way, my cat is really old and probably shot.
not sure if it will help with emissions but if you want the car to be a little cleaner maybe try some seafoam. hell it cant hurt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky »</TD></TR><TR><TD CLASS="quote">1st TIME <U></U>i went to emissions i got these readings
NOx--1006--197 PASS
Did some to0ning on a dyno, and made me a new chip and this is what i got 2nd time <U></U>around at EMISSIONs
Modified by patastinky at 9:08 AM 5/28/2004</TD></TR></TABLE>
Okay so i went back again.. as of right now i have about 15% of fuel taken out and im still not passing.. "NOx" is the hardest the emission guy said is to PASS i passed that, but how bout the "HC and CO%" what can be done to fix these!? take out more fuel!? i have already taken out 15% and im sure the car is running lean on the emission's dyno ( i have 2 chips, i dont drive w/ the emissions chip btw ).. Would retarding timing help at all here, to lower HC and CO% !?
here are my results, check out my "QUOTED" for the 1st and 2nd results
3rd time<U></U>Standard -- Reading --- RESULT
NOx 1006 -- 563 -- PASS
HC 132 -- 218 -- FAIL
CO% .73 -- 2.29 --- FAIL
NOx--1006--197 PASS
spoon95eg
Apr 23, 2006 11:28 AM
bonta-kun
16
Jul 12, 2005 12:18 AM
baonest1
11
Sep 21, 2003 05:54 PM
