Rear disc brake conversion
Old May 28, 2004 | 12:01 AM
NsX_CrX's Avatar
Default Rear disc brake conversion
Does anyone know what is needed to do a rear disc conversion for my '91 hf crx?
What kind of problems i will run into and basically how to do the conversion? Any info will help.
Old May 28, 2004 | 12:11 AM
ceLtic's Avatar
N/A wh0re!
Default Re: Rear disc brake conversion (NsX_CrX)
integra rear discs work, just need the e-brake cables, and if im not mistaken, the LCA? not sure though, i know for a fact its the cables, and possibly/most likely one other part.
Old May 28, 2004 | 05:33 AM
crx_88_si's Avatar
ebrake cables from a CRX are a perfect fit, teg cables need to be creatively routed. You dont need any control arms, just the trailing arm assembly. Also you will need the Brake lines.
Old May 28, 2004 | 06:15 AM
wpgcivic's Avatar
Default Re: (crx_88_si)
i did it in my garage in about 2 hours and its pretty much plug and play from a 90-93 teg
Old May 28, 2004 | 06:44 AM
Footwork's Avatar
just head on down to a salvage yard and pick up a complete 91 crx si rear trailing arm set (both left and right). the rear disks/calipers are already attached to it.
you can also get the e brake cable also.
this way it all bolts right up and you won't have to use anything from an integra.
Old May 28, 2004 | 07:25 AM
APEX CRX's Avatar
Default Re: Rear disc brake conversion (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">just head on down to a salvage yard and pick up a complete 91 crx si rear trailing arm set (both left and right). the rear disks/calipers are already attached to it.
this way it all bolts right up and you won't have to use anything from an integra.</TD></TR></TABLE>
Old May 28, 2004 | 08:21 AM
EL Vap133's Avatar
This has been covered many many times before. Just type in "rear disc brakes" in the search function, select this forum and you will see all the results. Don't forget about the archived threads.
mynameizstitch
10
Dec 13, 2009 03:06 PM
iheartmyh0nda
Apr 21, 2007 12:46 PM
sijeff
Jun 6, 2005 01:32 PM
d15civ
Oct 5, 2004 09:14 AM
lsvtecrx
22
Nov 8, 2002 02:02 AM
