About to ship a head, how do i clean it out so it wont leak oil everywhere?
Old May 27, 2004 | 11:08 PM
Civiclx's Avatar
Default About to ship a head, how do i clean it out so it wont leak oil everywhere?
can i use engine degreaser on the rocker assembly? carb cleaner?
Old May 27, 2004 | 11:14 PM
Br1anPham's Avatar
Default Re: About to ship a head, how do i clean it out so it wont leak oil everywhere? (Civiclx)
i used carbcleaner on my head to clean it back when i had the head taken apart and i have no problem with it now.
Old May 27, 2004 | 11:19 PM
Civiclx's Avatar
Default Re: About to ship a head, how do i clean it out so it wont leak oil everywhere? (Br1anPham)
sounds good. thanks bro!
Old May 27, 2004 | 11:24 PM
Br1anPham's Avatar
np, i don't know about engine degreaser. the only one i tried is gunk it works good but i don't know if you really want to spray it on and let it sit then wash it off with water. i just sprayed it and used a towel to clean it off. of it you have a lot of carb cleaner, spraying directly at it, the oil will just come off and just let it dry if you don't want to wipe.
But since your shipping the Head out, why would just let the head upside down and let most of the oil drip out then wrap it around in a old rag/ towel. If you happen to do clean it off real good, remember to tell whoever is recieving the head to make sure the cam and rocker assemply is well lubed before starting it for the first time. If its dry it will leave score marks on the cam
the only reason why i cleaned my head was so when i work on it, its not all oil and such. good luck
Old May 27, 2004 | 11:27 PM
Civiclx's Avatar
i think what im gonna do is buy tons of carb cleaner and just spray it on there while the head is upside down somehow then let it air dry. then im gonna put the head in a thick plastic bag similar to what oem headgaskets come in and wrap that in bubble wrap and tape it up. then put it in a box surrounded by packing peanuts and more bubble wrap. A cylinder head btw not a human head for those that jump into threads and dont read the whole thing. lol. Thanks again bro.
Old May 28, 2004 | 08:57 AM
-Trinitron-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">A cylinder head btw not a human head for those that jump into threads and dont read the whole thing. lol. </TD></TR></TABLE>
haha...I would suggest dry ice and a heavy duty cooler!
BauleyCivic's Avatar
Risky Business
Default Re: About to ship a head, how do i clean it out so it wont leak oil everywhere? (-TRINiTRON-)
brake cleaner
Old May 28, 2004 | 08:59 AM
Civiclx's Avatar
Default Re: About to ship a head, how do i clean it out so it wont leak oil everywhere? (BauleyCivic)
thanks bauley, my friend is getting a shipment of eg front clips in a week, imma ****** up an eg9 lip for you if he gets one!
Old May 28, 2004 | 09:07 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">thanks bauley, my friend is getting a shipment of eg front clips in a week, imma ****** up an eg9 lip for you if he gets one!</TD></TR></TABLE>
Nice !
Old May 28, 2004 | 09:50 AM
dsadas89das78934's Avatar
make sure you get all the little nooks and crannies when you clean it. the head i had shipped to me had obviously been cleaned before it was shipped, but a TON of oil managed to leak out onto the shirt he wrapped the head in.
Old May 28, 2004 | 10:11 AM
743power's Avatar
Default Re: (soccaian)
If you are leaving the rockers/valvetrain in, make sure there is some kind of pretectant on them so they dont rust. wd-40 or a little bit of oil or something along those lines.
Old May 28, 2004 | 11:00 AM
Civiclx's Avatar
Default Re: (x743x)
will they rust if i use carb cleaner?
Old May 28, 2004 | 11:09 AM
bbarbulo's Avatar
bag it in a garbage bag... several garbage bags. Then wrap it in bubble wrap and stick it in a box... fill the rest of the box with shredded newspaper or some confidential doc's from your workplace
Old May 28, 2004 | 11:39 AM
Civiclx's Avatar
Default Re: (bbarbulo)
yeah, i went ahead and put it in about 3 garbage bags, then wrapped the garbage bag in thick bubble wrap, then lined the box with bubble wrap and filled it with packing peanuts
Old May 28, 2004 | 12:23 PM
743power's Avatar
Default Re: (Civiclx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civiclx &raquo;</TD></TR><TR><TD CLASS="quote">will they rust if i use carb cleaner?</TD></TR></TABLE>
probably
Old May 28, 2004 | 02:48 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (x743x)
if you wanted maybe you can take it to a machines shop and get it hot tanked. just a thought.
Old May 28, 2004 | 03:05 PM
Kruzen510's Avatar
Default Re: (AzntaggeR)
if you have time and a couple bucks your local machine shop should do it for under ten bucks and it will be spotless inside and out
shbrown
May 12, 2005 05:47 PM
5thGenCivicKid
Dec 9, 2004 02:19 PM
flipchino
Mar 1, 2004 11:26 PM
95hbMatt
Jun 12, 2002 10:03 AM
AshlandSi
Nov 9, 2001 06:52 AM
