raise compression d16
Old May 27, 2004 | 08:02 PM
h22acivic4u's Avatar
Default raise compression d16
i have a 93 crx si head 1.6 port and polished and i have a 95 1.6 civic block the motor is in the car now running legit but i wana know if there is anyway i can raise compression with a thiner head gasket because i wana get a cam and if you know what kinda head gasket it is .....it would be great thanks alot for any info
Old May 27, 2004 | 08:06 PM
ABK's Avatar
ABK
Default Re: raise compression d16 (h22acivic4u)
where did you get a 93 CRX buddy?
Old May 27, 2004 | 08:10 PM
duh blacksheep's Avatar
Default Re: raise compression d16 (ABK)
isnt a crx a delsol in japan?
Old May 29, 2004 | 07:21 AM
i ment to say 90 either way its a crx head port and polished 1.6 non vtec how could i raise compression
Old May 29, 2004 | 09:54 AM
Discosteak's Avatar
you can deck the head or the block to raise comp. or find a thinner head gasket
Old May 29, 2004 | 11:03 AM
dogfood's Avatar
why would you waste the money on a cam for a 1.6 sohc non-vtec?
Old May 29, 2004 | 11:33 AM
ExospeedAMcrx's Avatar
Default Re: raise compression d16 (dogfood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood &raquo;</TD></TR><TR><TD CLASS="quote">why would you waste the money on a cam for a 1.6 sohc non-vtec?</TD></TR></TABLE>
why not?
to raise compression, use the y8 head gasket and for budget, you can mill the head a bit. I dont recommend that usually since it will leave you less room to play with on piston height if you ever decide to build up the bottom end.
you can get some good times on the sohc non-vtec. on our head packages with bolt ons, our customers average about 30-40hp gain to the wheels on just stock bottom end.
anonnonator
Honda Civic (2001 - 2005)
Jul 16, 2008 02:12 PM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
p1ccoloz
Apr 21, 2003 09:41 AM
extrmeboost
Mar 30, 2003 10:19 PM
turbod16y7vtec
Dec 27, 2002 09:06 PM
