My H22A4 in my Accord redlines at a weak 6000 rpm. What the #*$^( is the deal?!!?!
Old May 27, 2004 | 06:01 PM
MugenAccordSedan's Avatar
Default My H22A4 in my Accord redlines at a weak 6000 rpm. What the #*$^( is the deal?!!?!
I hooked up on a 95 Accord 4dr with an H22A4. Auto to manual conversion. Anyways, I've been taking it easy on this car for two reasons:
1. I just learned how to drive stick on it.
2. The front axle is in BAD shape.
So, I was at work today and me and a co-worker were out in the parking lot smokin' a cigarette by my ride. He asks me what it redlines at. I was like...I don't know...
I got in the car and tried and it redlined at the stock Accord cluster's redline. PATHETIC.
Could this be my MSD SCI ignition. I bought this car from another party so I don't know if this igntion has the rev limiter in it or not because from what I know, MSD has two versions of the SCI igntion - one with a rev limiter and one without. This might sound stupid but how do I tell if its my ignition box that is causing it to redline so early.
Thanks for all the help in advance.
Old May 27, 2004 | 06:03 PM
FatJoe's Avatar
Default Re: My H22A4 in my Accord redlines at a weak 6000 rpm. What the #*$^( is the deal?!!?! (MugenAccord
do you mean the rev limiter came in at 6000? what ECU are you using?
Old May 27, 2004 | 06:08 PM
Yeah, thats what I mean. I'm not sure, I think p13. I don't know, honestly. How do I tell?
Old May 27, 2004 | 08:05 PM
Andy4dtw's Avatar
look on the side of the ecu.....should have some numbers and b/t the 2 hyphens you should see what it is. For example, xxxx - p28 - xxxxx or xxxx - p72 - xxxx
Old May 27, 2004 | 08:32 PM
Nick H's Avatar
New User
Default Re: (Andy4dtw)
if you did this swap, you should definitely know what ecu you are using...perhaps the use of a wrong ecu is the problem of this occurance...
Old May 27, 2004 | 11:09 PM
AznPrideYo's Avatar
Default Re: (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">if you did this swap, you should definitely know what ecu you are using...perhaps the use of a wrong ecu is the problem of this occurance...</TD></TR></TABLE>
He didn't do the swap. He bought the car that way.
My friend put the wrong ecu in his gsr (like a tard) and it did the same thing so I agreem I would check the ecu.
Old May 27, 2004 | 11:13 PM
typeR#0427's Avatar
Default Re: (AznPrideYo)
Its the wrong ECU for sure, I have had the same problem a few times. If it is a chipped ECU it might be F'ed up.
Old May 28, 2004 | 01:19 AM
Eddiebx's Avatar
its also possible ur vtec is not working, hence the lower redline
Old May 28, 2004 | 03:47 AM
HAccord96's Avatar
Default Re: (Eddiebx)
Do you have a CEL? It might be running in "limp" mode. If you don't, then you are probably running a stock Accord ecu.
Old May 28, 2004 | 06:08 AM
v4lu3s's Avatar
RTFM
did you let teh car warm up at all?
if you didnt it is perfectly normal to rev limit that low. the ecu wont let the rev's build up too high unless the coolatn temp sensor says the car is warm enough.
Old May 28, 2004 | 07:43 PM
Default Re: (v4lu3s)
No I didn't warm it up that time but even on the highway it cuts me off at like 6000 rpm.
Old May 28, 2004 | 08:41 PM
Default Re: (hamB18C1)
Which ECU should I be using then? What is the best one?
Old May 28, 2004 | 09:31 PM
v4lu3s's Avatar
RTFM
do you know what ecu you have???
Old May 28, 2004 | 10:24 PM
secksiman19's Avatar
a p13 would be good
Old May 28, 2004 | 10:47 PM
FatJoe's Avatar
Default Re: (secksiman19)
hes got a p13... he also has an ignition that lets him se the rev limiter for drag and all that... so hell, thats prolly just it
Zain EuroR
Apr 3, 2019 02:43 AM
mrbighead
Feb 21, 2016 08:32 PM
Ruskimafia
Jan 1, 2006 05:23 PM
numbinside
Nov 1, 2004 11:19 PM
Agamemnon
Mar 4, 2002 07:35 PM
