Pressing out bushing
Old May 27, 2004 | 05:57 PM
HamiltonRex's Avatar
Default Pressing out bushing
What size press is required to do this?
I snapped off a bolt that holds the control arm to the traling arm. I cut the nut off the other side of the trailing arm, removed that. (old drum ones replacing with disc) Then i took off the control arm to try and remove the broken bolt stud. Its siezed in the bushing hardcore.
I need to press out the old bushing and press in a new one and get a new bolt, should i let honda do it, or what size press is required?
Thanks
-Eric
Old May 27, 2004 | 07:42 PM
mr. carpenter's Avatar
Default Re: Pressing out bushing (HamiltonRex)
there was a sweet *** thread about pressing bushings, if you search recent in this forum you'll probably find it.
Old May 27, 2004 | 08:24 PM
Default Re: Pressing out bushing (mr. carpenter)
i found it
http://www.performanceforum.co....html
Old May 27, 2004 | 11:40 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">what size press is required?</TD></TR></TABLE>
I have heard people using as small as a 6 ton press for bushings. Personally I spent a little extra for the 20 ton and I'm glad I did. So far there's nothing it can't move.
Old May 28, 2004 | 12:07 AM
CRX7's Avatar
Default Re: Pressing out bushing (travis)
That guy Wes Vann whose webpage you linked up is crazy. Man he fabs all kinds of stuff! Check out the entirety of his webpage if you haven't.
Old May 28, 2004 | 02:00 AM
Boosted Chemist's Avatar
Default Re: Pressing out bushing (CRX7)
on my front lca a 6 ton jack didnt do squat, i ended up using a air chisel to get those bushing out, the rest where straight forward, i need a press to get the trailing arm bushing in (not included in master kit_
supaman
Suspension & Brakes
Aug 4, 2016 06:47 AM
brewerkz
Jul 6, 2016 03:23 PM
Fnix
18
Jan 26, 2013 08:07 AM
jdmsupreme2132
Suspension & Brakes
Nov 6, 2009 03:19 PM
oo3
May 1, 2006 05:02 AM
