type-r block with b16a2 head and ctr pistons, what cr would it be?
Ok i would like to know what the compression ratio would be in the setup mention in subject.
Type-r block wit h b16a2 head and oversize pct's in there?
Thank you.
Thank you.
CR would be 11.04, that is assuming you are using a 3 layer headgasket.
I got this from some dude and I would like to pass it on to you.
Hope it helps... (it's pretty nifty)
http://www.bojangs.com/calculator/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civic_hb »</TD></TR><TR><TD CLASS="quote">CR would be 11.04, that is assuming you are using a 3 layer headgasket.
http://www.bojangs.com/calculator/</TD></TR></TABLE>
that sounds about right.
baulum
33
Dec 21, 2007 10:03 PM
SiBirdie
Oct 12, 2001 05:58 PM
