idle surges low...
Old May 27, 2004 | 05:18 PM
vannman's Avatar
Default idle surges low...
have a 98 prelude SH... i am having the old idle surge down to around 500 or lower RPM when you come down from around 2K to 3K or so problem. I cleaned my intake filter and cleaned out the throttle body somewhat. still has same exact problem... most noticable with the AC on. I want to say it is going to stall soon but it has not so far... so i should try adjusting the idle sqrew or what??? what about the cleaning stories of the FITV? i am new to the H22 and i have not even checked to see if we have one. I am very familare with the B series motors and all and i have cleaned those fitv's and it eliminated the problem of this type of surge.. some also had ECU problems and others various things like vac leakes. I know several of you H22 peepz have this problem... hit me up.
Old May 27, 2004 | 06:25 PM
delguiner's Avatar
Default Re: idle surges low... (vannman)
does your check engine light come on?
Old May 27, 2004 | 07:31 PM
Pr0jektLude's Avatar
i had the same problem for awhile on mine, it would jsut drop down around 500 or less...sometiems i had mine idle out where it felt like it was goin to stall...but i just tightned my throttle cable and adjusted my idle...havent had the problem since
Old May 27, 2004 | 07:34 PM
DIE DIE's Avatar
damn i got the same problem. how do i fix it? I already adjusted the idle screw. it idles perfect most of the time, but then it drops once in a while while im stopped at a light.
Old May 28, 2004 | 05:00 PM
97BlkSH's Avatar
Default Re: (seecretninja)
U guys might need to have a compression test done. The engine will do that if the compression is low in just one cylinder.
Old May 28, 2004 | 05:11 PM
Shakes's Avatar
space cadet
Default Re: (97BlkSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97BlkSH &raquo;</TD></TR><TR><TD CLASS="quote">U guys might need to have a compression test done. The engine will do that if the compression is low in just one cylinder.</TD></TR></TABLE>
also it wont hurt to clean the IACV.
Old May 28, 2004 | 05:25 PM
hOndafienD 04's Avatar
my 92 si also idles at about 500 when it warms up...i raised the idle and itsok now, but sometimes still drops....you guys think it might be something with the iac...my check ebgine light don't work so i don't know if it has a code or not..
also how would i clean the iac valve??? thanx a lot
Old May 28, 2004 | 05:29 PM
specalk's Avatar
Default Re: (hOndafienD 04)
i cleaned my iacv and it did not fix it for me, but then again i got 80k and no valve adjustment on my car so that might have something to do with it
Old May 28, 2004 | 07:49 PM
AcidSun's Avatar
i had a similar problem but i got so bad i started stalling.. the problem was linked to my distributer
Old May 29, 2004 | 07:29 AM
delguiner's Avatar
Default Re: (AcidSun)
Ya you have to fix your check engine light, cause that way you can check for engine codes... i had the exact same idling problem on my car, that sometimes it would idle really low and the engine would shake and smell of gas and oil. So i checked for engine codes and i got 2 of them.
Old May 29, 2004 | 07:37 AM
specalk's Avatar
Default Re: (delguiner)
what were they
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">Ya you have to fix your check engine light, cause that way you can check for engine codes... i had the exact same idling problem on my car, that sometimes it would idle really low and the engine would shake and smell of gas and oil. So i checked for engine codes and i got 2 of them.
Old May 29, 2004 | 07:54 AM
tekkynikality's Avatar
Default Re: (specalk)
Or you can just install a fuel pressure regulator.. guaranteed to fix things.
Old May 29, 2004 | 08:05 AM
delguiner's Avatar
Default Re: (tekkynikality)
12 Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98
EGR Lift Sensor (Exhaust Gas Recirculation)
defective circuit or unplugged / defective sensor
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
43 Fuel Supply System
defective or malfunctioning fuel supply system
Old May 29, 2004 | 04:14 PM
specalk's Avatar
i still donot get why mine does it, i had the battery checked at auto zone and it read out 10volts. Ive never had a valve adjustment and i have 80k miles, i cleaned out my IACV both coolant line and the little screen part. Ive never cleaned out the EGR valve but im not sure how to
Old May 29, 2004 | 06:49 PM
vannman's Avatar
It only happens mainly with the AC on well after the engine warms up. happens a little bit without the AC on but not near as bad... only when warm.
Old May 29, 2004 | 07:16 PM
Freemantle's Avatar
Default Re: (vannman)
I had that problem after beating on the motor in the warm. Ends up taht the coolant flowing through the IAC valve was warming my intake charge in a huge way. I disabled it (re-routed the coolant) and haven't had the problem since.
Old May 30, 2004 | 05:18 AM
specalk's Avatar
Default Re: (Freemantle)
same problem here, it drops like a ****** with the AC on but a little bit with it off, like expample when i drive around a little bit like 5-10 miles and stop somewhere and turn my car off for a few sec to go inside then come out start it back up and i go to back up a little bit take my foot of the gas and the rpms drop to zero car shakes then gos back up.
i found out a while ageo that the coolant line for the iac was blocked so i cleaned that a while ageo and had the entire coolant system flushed, and back then i was getting a flux idle problem when it was cold outside, doing that fixed it. but i got this other problem
i went to one auto zone they checked my battery out the guy said u got a bad battery, i was like what volts is it reading he said it just says bad battery, im like ok, so i go to another auto zone and they test it and it says 10volts need to charge, this was after driving my car 15+ miles, but my car sits all week with the alarm on it so imight have a bad memory, my cars all messed up
philep_cb7_91
Feb 21, 2010 11:28 AM
sohcondis
Feb 15, 2008 12:10 AM
t3ddy_lee
Jun 28, 2007 02:12 AM
95accordh22a
Mar 31, 2005 11:47 AM
blackE_T
Feb 4, 2005 01:59 PM
