brake light does't work HELP
i have a 94 integra and teh brake light doesn't work. didn't know it didn't work til the cop pulled me over and gave me a fix it ticket. anyways, all the fuse are fine and lights all work. but when i step on the brake, it doens' work. everything lights up at night but not the brake lights when i step on it. does anyone know how to fix this problem?
you say your brakelight [not brakelights] is not working , do you mean the anticollision light [or center brakelight] or do you mean non of them work? ill take it as none of them work , as you should start at the top to find problem for both. 1 check fuses underdash and underhood [dont just look at them ,use a volt meter or "ecu safe" testlight] test that you have power on both pins of fuse [you can do this with fuse in place] if all ok. 2 test brakelight switch [underdash high up on brake peddle, also leave in place] will have at least 2 wires in it, one [feed] will have 12v+ on it all the time , now test other wire/wires and [if more then one]at least one will have 12v+ on it when you step/push on peddle[you shouldnt have to step/push very hard] if no ,check and see that pinswitch [held into brakelight switch by brake ped.arm] comes out all the way. if not adjust,[brake ped.arm should not be in contact with pinswitch tip when peddle pushed more then 1or2 in. if still no power replace switch.if all ok.3 test brakelight bulb socket [remove bulb] have someone step on brake while you test for 12v+ at pin at bottem of socket, if no. check all harness plugs at,into and around fuse box [inside one] and behind kik pan.below fuse box, if all ok. you will have to check harness running to back of car [starts behind drivers kik pan. and runs dowen drivers side of car[kik pan. and rockerpanal cover and rear seat are easy,rear side pan. is a bit of a pain] check ground in bulb socket [on inside side of socket] before you check harness.if all ok
your pissing into the wind. hope this helps 94
all the bulbs are fine. none of the brake light go on when i step on the brake pedal. where is exactly the lever at? is it a lever or just a button?
btw, its a 4 door
btw, its a 4 door
the brake pedal[the part you step on] is mounted to the lever the lever is mounted to the pivit the pivit is mounted to th........................................anyway, part way up the "lever" [or mounted next to it] is the brake switch[pin switch][ because it has a pin in it that is held in by the brake lever or bracket on the lever] ,you have to check and see that its working [ its what supplies 12v+ to the brakelights] the pin must slide in and all the out way out when you step/push on the brake, it has to have 12v+conn. [live all the time] into it, it has to have 12v+ out of it [on another wire]when you step/push on the brake pedal. if your having brake light problems [all the brakelights] this is where to check after checking fuses. ps get a manual for your car [not a shop manual big big $$$] just one of them ones you can get at your parts store,it can be a big help if your going work on your car yourself [like you would have known where the brakeswitch was lol. hope this helps 94
sorry to bump an old topic, but i was wondering if anyone could help me.
I have an 89 civic hatch and my third brake light is not working. The fuse under the hood marked "Stop/horn" is fine and the horn works. I got new blubs cuz i though the one in there was out, but it still didnt work. I tested the old bulb with a battery and it works, so i now know it's gotta be the circuit somewhere.
Should i just trace the wires around and look for a loose one or does anyone have any nifty socket connection cleaning tips?
I also had a question about the door jamb switch in my car; I have no idea where it is... I've looked all over the door and have not found anything resembling a switch or button or contact of any kind. any help?
b16a2pwr
Feb 14, 2004 02:28 PM
