problem starting?
every once and while my car doesnt want to start. it just keeps tryin to turn over but i have to turn it all the way off and then try it a couple more times. do u think it would b the spark plugs or should i see about the starter. the car is still under warranty to lemme know. thanks
Its your fuel pump relay, you can check it by turning the key one click and listening for the fuel pump to activate, do this a few time without starting it, the first time you hear it not active the fuel pump try to start the car it, wont start,,, your might have to listen real hard
ok well i tried that and the thing worked everytime. its like a light buzz and then it shuts off. i did it about 15 times and it worked everytime. so if anyone else has any suggestions
It still sounds like your main relay (what the other man said). read this and you will understand that main relays can be tempramental. http://www.markl.f9.co.uk/howt...y.htm
LilMissCrystal81
Nov 19, 2004 11:26 AM
is there any other possibilities?
