ZC DOHC DISTIBUTER problems
Old May 27, 2004 | 01:35 PM
ghost_ryder35's Avatar
Default ZC DOHC DISTIBUTER problems
I just got my distibuter yesterday for my DOHC ZC and I wired it up and plugged it in. The car wont turn on. I looked in the chilton and the firing order is 1342, correct me if I am wrong there. The car tries to turn on but nothing happens. I checked all the wires for spark and they all have spark. I played around with the firing order a little and almost got it to work but it didnt. Anyone with a similar problem? If anyone could help it would be greatly appreciated.
-nick
Old May 27, 2004 | 01:40 PM
4drEF's Avatar
Keyboard Humorist
Default Re: ZC DOHC DISTIBUTER problems (ghost_ryder35)
Are you injectors firing? ... smell like gas?
Old May 27, 2004 | 01:41 PM
Default Re: ZC DOHC DISTIBUTER problems (4drEF)
yes I do have fuel at the injectors.
Old May 27, 2004 | 02:12 PM
DJ_SaNdOz's Avatar
have you triple checked the wiring? I'm assuming that this is a new motor swap, and not just a dizzy replacement.
Old May 27, 2004 | 02:19 PM
4drEF's Avatar
Keyboard Humorist
I snagged this picture from a different post - what are you calling the #1 post on your distributor?
What are you calling #1 on the distributor?
Is you timing belt timing correct?
Old May 28, 2004 | 05:39 AM
timing is good. does anyone know what wire on the plug you have to rewire would make the car not start... i have triple checked the wiring a million times and it sitll wont start. help
Old May 28, 2004 | 07:02 AM
90SICRX's Avatar
I thought with the DOHC ZC you have to switch the wires around on the distributor? When you siad you used the chiltons manual was it for the d16?or D15? depneding on what car you have. I'm not sure where the wires are supose to be switched but try researching that.
Old May 28, 2004 | 10:07 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 &raquo;</TD></TR><TR><TD CLASS="quote">timing is good. does anyone know what wire on the plug you have to rewire would make the car not start... i have triple checked the wiring a million times and it sitll wont start. help</TD></TR></TABLE>
Did you rewire the cars wiring harness to match the Teg dizzy, or did you rewire the plug on the dizzy to match your car's wiring harness?
Typically when it won't start in my experience, it's because the two white wires are switched around. That's how it was on my Si & friends Si at least. Answer my question so we can help diagnose better......
Old May 28, 2004 | 05:47 PM
Default Re: ZC DOHC DISTIBUTER problems (DJ_SaNdOz)
i get off work tonight at 1030 so I will go home and switch the two white wires. will reply when i get it done... thanx!
Old May 28, 2004 | 07:25 PM
StupidSlowRSX's Avatar
sigh... I cant believe no one has asked this question yet.
Does the car turn over? Cranks but wont start?
Yea? Check your grounds located at Valve Cover, Thermostat housing, and battery, as well as tranny ground.
Old May 28, 2004 | 11:03 PM
mr. carpenter's Avatar
Default Re: (StupidSlowCRX)
make sure that the rotor is on correct. some distributors are threaded all the way through allowing the rotor screw to go in either side, thus allowing you to install the rotor 180 degrees.
Old May 29, 2004 | 01:36 PM
car does crank but wont turn on.... checked wiring today for the millionth time and it is perfect... abosolutley nothing is wrong... all the opproriate colors are where they need to go everything is wiried how its suppose to be.... I didnty know that about some of the rotors so I will take the cap off tonight and the rotor and check to see if it can be rotated 180 degrees. respong when i do it tonight when i get off work.
thanx for all the help
-nick
Old May 29, 2004 | 02:13 PM
Default Re: (ghost_ryder35)
http://www.thezcr.com/forums/s...dizzy
reminder for my self
-Check two white wires again (and again and again)
-Rotate rotor 180 degrees (if possible)
Modified by ghost_ryder35 at 7:18 PM 5/29/2004
Old May 31, 2004 | 12:09 AM
DJ_SaNdOz's Avatar
is it running now? was it the rotor or wires if it is up & going? just thought that i'd check in.....
Old May 31, 2004 | 10:27 AM
Default Re: (DJ_SaNdOz)
still down... i got a lot closer though. this time it sounded incredibly healthy trying to turn on ... the rotor cant be turned 180 degrees though. so i still cant find the prob but feel confident getting closer. post back in a few minutes trying something.
Old May 31, 2004 | 10:54 AM
Bgladfelter's Avatar
Are you getting spark? I've gotten a "new" distributor with a bad coil in it, and had the same problem. Another trip out to the store, and she was running.
Old May 31, 2004 | 04:23 PM
Default Re: (Bgladfelter)
finally got it working... for some reason the 1342 firing order isnt it for the motor. this brings me to another thing about this motor that I bought from SOKO. my pressure plate from old zc which i had blown up didnt match up to the flywheel when it was shipped to my house. so i had to go out and get an act flywheel but anyways thanx for all the help. I will post what the firing order is when i go out tonight and finish a few things on the car.
Old May 31, 2004 | 07:50 PM
DJ_SaNdOz's Avatar
glad it started
stickman78114
Feb 28, 2010 11:59 AM
poopycar
Nov 2, 2004 11:26 AM
Crx-Racer4Life
Jul 3, 2004 12:18 PM
efjuice
Sep 22, 2003 06:05 PM
civic2299
May 11, 2002 06:45 PM
