10mm or 12mm tool for the civic's?
On a Dseries, if a valve adjustment tool is what you are after, then you dont need a tool. On a Bseries, then the nut on top of the valve is 10mm.
Thanx, I went and opened the valve cover without the "tool" and then just went to work adjusting the valves.....stink of it is, the noise didn't go away even though I rechecked the valves twice......hrm.
too late already done but yup....sat overnight....lessons learned for me.....REMOVE THE SPARK PLUGS....i felt stupid trying to turn the engine with them in.
99gsrfasho
Dec 31, 2009 10:07 PM
