Airbag removed, SRS light
Old May 27, 2004 | 09:45 AM
Siegfried's Avatar
Default Airbag removed, SRS light
Hi,
my cousin changed his steering wheel in his accord with an aftermarket one, now the SRS light is ON.
I read some threads about SRS, they tell how to reset it but as the Airbag has been removed, it' ll light again.
I would like to know how to fool the controler, so it' ll think the airbag is still there, I read that you have to put a resistor. what' s the value of the resistor to use ?
Old May 27, 2004 | 09:59 AM
-RedneckDave-'s Avatar
Working
Default Re: Airbag removed, SRS light (Siegfried)
You will have to use an ohm meter and find out what resistor to use, or you could look in a wiring diagram and see if it tells you what you need.
Old May 27, 2004 | 10:01 AM
.bagged's Avatar
Default Re: Airbag removed, SRS light (-RedneckDave-)
If its a 6th gen..Check the Basic Guide at the top of the forum and Iam7head did a nice write up on how to reset it
Old May 27, 2004 | 12:45 PM
Siegfried's Avatar
I didn' t find 98 wiring diagram, but on 96 diagram, it doesn' t tell any resistor value.
No one have an aftermarket steering wheel and put a resistor to remove SRS light ?
Old May 28, 2004 | 02:48 PM
Juccord's Avatar
I just took the bulb out of the cluster, no more SRS light! I like the cheap easy way out.
Old May 28, 2004 | 06:02 PM
Siegfried's Avatar
Default Re: Airbag removed, SRS light (Juccord)
I think it' s easier to put a resistor than to remove part of the dash for a bulb (don' know if it' s really difficult to remove as it' s not my car, will check when I' ll see him in case we don' t find the resistor value), that' s why I' m asking the resistor value.
lsturbo00
Oct 5, 2009 04:22 PM
i hate import cars
Jun 12, 2008 01:12 PM
english-seth
Nov 20, 2006 02:56 AM
Xgen
Jan 8, 2006 06:42 AM
timmy0tool
Apr 27, 2005 08:13 PM
