a few questions about engine displacements...and bottom end components
Old May 27, 2004 | 09:32 AM
z6's Avatar
z6
Default a few questions about engine displacements...and bottom end components
i have a b18c1 block, same as the b16b(which is what im trying to make!)
#1 are the b16a cranks and b16b cranks different, if so how?
#2 what is the max bore i can use with a set of benson sleeves that will be safe up to 500hp? 86mm? bigger?
# how much displacement do you get out of a b16b bored out to whatever you answered in question #2?
Old May 27, 2004 | 03:05 PM
Rocket's Avatar
Default Re: a few questions about engine displacements...and bottom end components (z6)
B16B crank is a lil diff than B16A crank since B16B rods are like B18C rods.
As for bore size 82-83mm is good for FI since the turbo does the pumping and not the pistons alone.
I like to run 82mm and we've had really good success with that.
viciousef9
10
Mar 18, 2009 05:25 AM
amadriga
Sep 4, 2007 02:58 PM
DC2 Mang
12
Mar 9, 2006 05:47 PM
rogue3221
Jun 7, 2004 12:56 PM
-KangaRod-
Aug 26, 2003 09:28 AM
