b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help!
Old May 27, 2004 | 08:49 AM
iNetForce's Avatar
Default b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help!
guys i dont have vss on my car, is a 88 crx, car is obd1, im running a b16a2 with a 95 gsr ecu, im getting code 17 which is vss. How do I fix this? What do I need?
different cluster? vss cable?
need a list of stuff
thanks again.
Old May 27, 2004 | 09:41 AM
Craig-88CRX's Avatar
Default Re: b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help! (iNetForce)
i think you need to get a vss cable or get a cluster that dosent use vss
go to http://www.ef-honda.com/ben
he was my best friend and he did a write up on it and has some pics o fhow to wire it when we did the same thing in my car when put a 96 integra cluster in my 88 crx that has a b16 with lsd. if you have any other question let me know i will go and take a look on my car for you. I know what you are going through i went through the same thing, we did it by trial and error. we had the battery ligh blinking at the speed that we were going. we had it all mesed up but finally got it al workd out and works fine now.hope i have helped you a little.
craig
Old May 29, 2004 | 05:27 PM
if you take the speed censor off of your old tranny, you should be able to put that one in the new tranny and it schould all work ok
Old May 30, 2004 | 07:37 PM
michael O's Avatar
If you're still having a problem check this out.
https://honda-tech.com/zerothread?id=880736
Old Jun 1, 2004 | 09:18 PM
so did you get everything worked out what did you do
Old Jun 1, 2004 | 09:19 PM
iNetForce's Avatar
Default Re: b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help! (Craig-88CRX)
nothin yet, im stll looking for some parts
Old Jun 2, 2004 | 05:42 PM
keep me posted
Old Jun 2, 2004 | 06:25 PM
iNetForce's Avatar
k
fox_the_shadow
Mar 12, 2012 09:09 AM
timdareez
10
Sep 10, 2009 05:39 PM
HT Chaplain
Oct 25, 2006 08:26 PM
jonathancrx
Jul 17, 2005 05:17 AM
iNetForce
May 30, 2004 07:38 PM
