K series question.
Old May 27, 2004 | 08:02 AM
JDMotive's Avatar
Default K series question.
What are the sleeves made out of?And can aftermarket pistons be used without having to resleeve?I was just wondering because both the h22 and f20c have FRM sleeves,and aftermarket pistons are too harsh for them.Thanks.
Old May 27, 2004 | 08:38 AM
GZERO's Avatar
Default Re: K series question. (JDMotive)
i don't know, but IMHO you could bet they are FRM.
Does anyone knows for sure?
Old May 27, 2004 | 08:46 AM
JDMotive's Avatar
Default Re: K series question. (GZERO)
I did a search on google....typed h22 FRM and alot of stuff came up...same for s2000 FRM...but nothing happened when i typed rsx frm or k20a2 frm except i got links to threads that had frm info in them.
Old May 27, 2004 | 08:25 PM
StorminMatt's Avatar
It seems like most sleeves are made of either cast iron or nodular iron. As for pistons being 'rough' on the sleeves, this can happen if you use low silicon race pistons. Because they expand more than higher silicon forged pistons or cast pistons, they have to be run looser. This causes the pistons to slap around in the cylinders as the engine warms up. And as you might guess, this is why they are rough on cylinders. This wear gets especially bad if you drive away on a cold engine as you would with a normal street motor (as opposed to warming the engine up before driving away). For this reason, low silicon forged pistons are not a good choice for a street motor. They are noisy when cold. And longevity is not good.
Old May 27, 2004 | 08:48 PM
Kal's Avatar
Kal
they're steel sleeves.
Old May 27, 2004 | 09:16 PM
JDMotive's Avatar
Default Re: K series question. (StorminMatt)
storminmatt-..thanks for the input,but i knew most of that already....thats why i was wondering about the sleeves....FRM sleeves are softer than normal iron sleeves and aftermarket forged pistons can be rougher on them than on normal iron sleeves..
Kal-what kind of steel and can low silicon pistons be used without damaging the sleeves?
I really just need to kow if they are made of FRM or not...it seems like nowadays alot of honda's "good" engines use FRM sleeves....i hope not though.
Old May 27, 2004 | 09:37 PM
Joseph Davis's Avatar
As far as FRM goes, JDogg was telling me a while back they make FRM compatible forgings now for the H22. Drop into the stock bore, enjoy. PM him with questions
Old May 27, 2004 | 10:10 PM
JDMotive's Avatar
Default Re: K series question. (J. Davis)
thanks,i will.
Old May 27, 2004 | 10:20 PM
Kal's Avatar
Kal
i believe the k-series engines use the steel similar to the b-series motors(post in the ep3/dc5 section to make sure) and i'm not sure about the low silicon pistons.
but i am sure they're steel and not FRM.
FRM is only in the h22a,f20c,c32a.
And there's only one definite piston that works in the stock FRM sleeves and that is Jun Pistons (Special alloy). All others claim to work, but in the end, they usually fail.
Old May 27, 2004 | 10:25 PM
JDMotive's Avatar
Default Re: K series question. (Kal)
thanks for the help....ive never done work on e=an engine with FRM sleeves so wasnt sure and didnt want to have to resleeve to run aftermarket pistons
Old May 28, 2004 | 08:49 AM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">FRM sleeves are softer than normal iron sleeves and aftermarket forged pistons can be rougher on them than on normal iron sleeves..</TD></TR></TABLE>
What? FRM is stronger, think about it, why is it used on all high compression honda engines? (especially BIKES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">I really just need to kow if they are made of FRM or not...it seems like nowadays alot of honda's "good" engines use FRM sleeves....i hope not though.</TD></TR></TABLE>
I'm shocked that they aren't FRM as KAL said.
Old May 28, 2004 | 09:28 AM
JDMotive's Avatar
I didnt say FRM was weaker, I said it was softer.
H-EK22
24
Feb 2, 2008 06:52 PM
EM2Civic
Feb 27, 2005 05:01 PM
christoble
Jan 2, 2005 08:02 PM
AutoLab
Aug 6, 2004 04:50 PM
