HELP HELP HELP car will not start!!!!!
Old May 27, 2004 | 07:49 AM
daidilus's Avatar
Default HELP HELP HELP car will not start!!!!!
I was removing a mount, and removing my battery, I someone how cut the wires to the 2 relays under the hood, (a/c compressor,conderser fan) they are, next to the passenger side headlight, i tried to start the car, all i heard was a buzzing from my main relay, and the check engine light is really dim when it makes the buzzing noise, so i replaced it, and it does not buzz, but now I have no injectors or fuel pump : what to do what to do? would this happen if i did not have the ground hooked back up
Old May 27, 2004 | 07:56 AM
90SICRX's Avatar
Default Re: HELP HELP HELP car will not start!!!!! (daidilus)
Check all your grounds, and check to make sure someone didn't cut any other lines??
Old May 27, 2004 | 08:02 AM
sporkcrx's Avatar
Default Re: HELP HELP HELP car will not start!!!!! (90SICRX)
Did you cut the wires when the battery was connected? If so check your fuses. Hell check them anyways.
Old May 27, 2004 | 08:09 AM
RobbieG35's Avatar
12 Years Strong
Default Re: HELP HELP HELP car will not start!!!!! (sporkcrx)
Check the fuses, you most likely popped something important
Old May 27, 2004 | 08:24 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">Did you cut the wires when the battery was connected? If so check your fuses. Hell check them anyways.</TD></TR></TABLE>
definitely check the fuses. mains and under the dash
Old May 27, 2004 | 08:59 AM
daidilus's Avatar
Default Re: HELP HELP HELP car will not start!!!!! (APEX CRX)
i checked everything, and no the battery was not connected, if i unplug anything, there is no buzzing, just the relay's click
hurraquio
Feb 4, 2006 07:34 PM
Scooter000
Sep 16, 2005 03:35 PM
ben_jums
Jun 14, 2005 04:55 PM
hatchinprogress
Jun 6, 2005 07:22 PM
CRzex
Nov 4, 2001 10:24 AM
