Honda S2000 Honda S2000
What size rims are on the NSX? and.....
Old Nov 9, 2001 | 11:23 AM
1996GsrVtec's Avatar
Default What size rims are on the NSX? and.....
Will the nsx rims fit the bolt pattern on an Integra Type R
Old Nov 9, 2001 | 12:44 PM
grippgoat's Avatar
Default Re: What size rims are on the NSX? and..... (1996GsrVtec)
Bolt pattern is the same, offset and center bore will be a problem.
Early model NSXes are 15x6.5 +55mm front and 16x8 +60mm rear. Don't recall exactly the center bore, although the front is circa 70mm and the rear is circa 64 I think.
I don't remember the exact sizes of the 94+ wheels, however, I do know the offsets are the same. It might be like 16x7 and 17x8.5 or something like that. Check http://www.nsxprime.com.
Anyway, it's possible to get 'em to work on an ITR, but you'd need spacers and longer lugs for sure.
-Mike
wrXtian
Sep 27, 2010 08:39 AM
Decatur Racer
Dec 30, 2008 06:53 PM
GqchYnAbOy
Honda S2000
Aug 12, 2003 10:32 PM
Cowtit
May 6, 2003 10:00 AM
1996GsrVtec
Dec 28, 2001 05:31 AM
