Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what would be a better platform?
Old May 27, 2004 | 03:33 AM
sebmour jdm's Avatar
Default what would be a better platform?
for lapping and autocross, wich would be the better platform between an integra DA or an EG civic hatchback.
Will put in roll cage cage, better brakes and suspension. for the engine eg = swap and da = ls/v-tec.
Thanx for your input.
Old May 27, 2004 | 03:39 AM
.RJ's Avatar
.RJ
Default Re: what would be a better platform? (sebmour jdm)
Doesnt matter.
If you're serious about getting out on track, buy either one, dont do a swap, make sure the car is not busted, put tires and brake pads on it and go have fun
Old May 27, 2004 | 08:11 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: what would be a better platform? (.RJ)
What he said. Track time is the best upgrade you can ever do. Besides that, starting out with a lightweight powerful car is not the best way to learn. I wish I could've started with an old, stock EF or something, seems like I would've learned some of the basics a bit better.
On a somewhat similar topic, RJ I know you had a DA for awhile, from the little bit of searching I've done, it seems like suspension options are limited compared to options for an EG or DC. Thoughts?
Old May 27, 2004 | 09:52 AM
missliz's Avatar
Default Re: what would be a better platform? (sscguy)
doesnt really matter.
Old May 27, 2004 | 10:41 AM
I was leaning on a DA cause the integra seems like a better platform. But i'm hesitant also with th eg v-tec (sohc) cause easy to swap 5 lug (better brakes) and other type-r components.
Old May 27, 2004 | 10:57 AM
.RJ's Avatar
.RJ
Default Re: (sebmour jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sebmour jdm &raquo;</TD></TR><TR><TD CLASS="quote">easy to swap 5 lug (better brakes) and other type-r components.</TD></TR></TABLE>
Wont matter.... leave it somewhat stock and have fun, alot cheaper.
Old May 27, 2004 | 11:02 AM
Xian's Avatar
you don't need massive brakes for a lightweight EG with the stock engine... just a good set of pads.
Boostn B20
Aug 21, 2008 04:45 AM
Ssaacckkeedd
Mar 24, 2007 09:13 PM
jaydmcrx
Nov 15, 2005 05:07 PM
AmginE
Oct 23, 2004 10:07 AM
Mugen_R
21
Nov 15, 2001 07:55 AM
