replacing brake master cylinder
Old May 26, 2004 | 09:05 PM
bOOsTiNSoHcVtEc's Avatar
Default replacing brake master cylinder
Im going to be replacing my brake master cylinder in a couple of days and i was wondering if there was a easy way to drain the brake fluid without getting to much air into the lines? Thanks..
Old May 27, 2004 | 05:49 AM
JimBlake's Avatar
Default Re: replacing brake master cylinder (bOOsTiNSoHcVtEc)
Suck the fluid out of the reservoir with something like a turkey baster. Then put rags under the MC, & don't actually drain the lines. You'll spill a little when you disconnect the lines, that's what the rags are for. But you'll STILL have to bleed the system when you're done.
Old May 27, 2004 | 06:26 AM
Farmer Brown's Avatar
Default Re: replacing brake master cylinder (JimBlake)
Yea once you take the lines off you need to bleed the system. However they do make brake kits that would make it possible to reverse bleed it back into the master cylinder. However it would be better just to get all that old fluid out of there anyway and you dont want to be pumping dirty fluid back up the lines, especially if you have ABS.
Old May 27, 2004 | 11:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaSt0rProcrastinat0r &raquo;</TD></TR><TR><TD CLASS="quote">Yea once you take the lines off you need to bleed the system. However they do make brake kits that would make it possible to reverse bleed it back into the master cylinder. However it would be better just to get all that old fluid out of there anyway and you dont want to be pumping dirty fluid back up the lines, especially if you have ABS.</TD></TR></TABLE>
Wouldnt that put air between the master cylinder and the lines? So that would mean i would be bleeding all day? Or does it come out faster than i think?
Old May 27, 2004 | 12:10 PM
integra6650's Avatar
theres nothiing you can do about getting air in the lines brake fluid is 2 dollars a quart your gonna have to come to terms and buy some
Old May 27, 2004 | 12:58 PM
Default Re: replacing brake master cylinder (integra6650)
haha yeah i know..i jus dont wanna be out there bleeding the brakes all day
dgdarien
Sep 25, 2009 06:25 PM
steronz
Apr 7, 2007 10:22 AM
jetpilot
Jul 5, 2004 06:48 PM
mattL
Apr 29, 2004 04:10 AM
Volcom
Mar 16, 2002 09:04 AM
