D Series swap question
Old May 26, 2004 | 08:45 PM
emark4's Avatar
Default D Series swap question
hey whats goin on i need some help ok so im putting a 95 d16z6 in my 94 cx so no big deal right... i need some help tho on the wiring i dont know how to make the vtec engage what do i need to do to my stock harness? thanks for your help guys i did a search but all i got were b16 swap info
Old May 27, 2004 | 07:16 AM
tgreaves's Avatar
Default Re: D Series swap question (markydeg)
You can follow the same guidelines that everyone uses for the B16 swap.. All your doing it sending 12 volts to the vtec noid at a certant rpm..
Old May 27, 2004 | 07:37 AM
Kendall's Avatar
You'll need to run 3 wires for VTEC, one from the solenoid, one from the pressure switch, and a chassis ground. Also, you may have to add/relengthen some wires to get the O2 sensor sorted out.
Old May 27, 2004 | 08:41 AM
tgreaves's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You'll need to run 3 wires for VTEC, one from the solenoid, one from the pressure switch, and a chassis ground. Also, you may have to add/relengthen some wires to get the O2 sensor sorted out.</TD></TR></TABLE>
Whats different with the o2 sensor.. Its an obd1 car??
meallout
Jul 5, 2008 05:45 PM
ExclusiveCRX
11
Feb 27, 2007 06:17 AM
del-sol-95
Jun 14, 2006 09:08 PM
new06member
May 30, 2006 07:30 AM
0 0 0
Sep 15, 2003 06:25 PM
