DIY Paint job? post pix!
Old May 26, 2004 | 08:45 PM
JaY-R's Avatar
Default DIY Paint job? post pix!
has anyone done their own paint job??? if so.. show pix!!!
i am doing my jdm conversion and lots of other body mods and am thinking about painting the car myself...
if you guys done ur own.. let me know some tips and like.. what i would need.. any paint sprayer suggestions.. etc
btw... i am NOT jumping into this outta no where with a spray can... i just want to look into diy paint jobs more... most likely i'll bring it to a shop...
Old May 26, 2004 | 11:51 PM
dawalude's Avatar
Default Re: DIY Paint job? post pix! (b18bb0y)
i helped out a friend do his 93 prelude, along with another friend making it 3 people working on the car. total time was a week, working about 6 hours each day. total cost = $100 his pocket. he treated me and our other friend out to lunch. we did it for the learning experience
Day 1: washed car and removed hood, fiberglass kit, fenders, weather strip around door. applied aircraft paint remover on the car to bring it down to bare metal. after it dried, scraped everything off. car is stripped of paint and is down to bare metal. did the same for the hood and fenders.
Day 2: bought several cans of primer (forgot how many it was last summer). each of us concentrated on a particular part on the surface. we sprayed about 2-3 coats of primer, applying light coats each time. in between each coat we wetsanded with 400 grit sandpaper. end of the day car was primered.
Day 3: bought several cans of paint (kragens, autozone, etc.) we used the same procedures as when we were doing the primer. 2-3 light coats, let dry. this time we didnt sand until we put the final 3rd coat on. wetsanded at 1000 grit sand paper.
Day 4: we looked over the car to see if we needed to touch up anywhere. applied more paint where needed. wetsanded car with 1000 grit sand paper again. most of the time today was spent wetsanding.
Day 5: bought several cans of clearcoat. used the same steps as primer and paint. we waited till the very end to wetsand it with 2000 grit sandpaper. it seemed like the clearcoat needs a lil longer time to dry before touching it in any way, or else your finger print will appear haha
Day 6: the car is basically done. we applied rubbing compound on the surface of the car to remove imperfections, scratches, to basically blend the clear into the paint. spent a lot of time with this. reinstalled all the parts that were previously removed.
Day 7: done with the car. from a distance it looks good but up close you can tell that its spray painted. surface is very smooth tho because we spent a lot of time wetsanding. washed/waxed car and we're done.
Recommendations: if you ever consider this, take your sweet *** time. once you start to rush, you will see paint drips, a lot of little imperfections. remove all plastic/fiberglass parts before applying paint remover. make sure when you wetsand, the surface is very wet. we used a hose and/or bucket of water at all times. i think thats about it that you need to know. since then his car has now been repainted at my uncles body shop and looks much better than before..but for a $100 paint job it looked good..good luck with whatever you do
Old May 27, 2004 | 12:05 AM
kicker1_solo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bb0y &raquo;</TD></TR><TR><TD CLASS="quote">has anyone done their own paint job??? if so.. show pix!!!
</TD></TR></TABLE>here ya go
Old May 27, 2004 | 12:54 AM
nightrider's Avatar
Old May 27, 2004 | 01:05 AM
gaydm.accord's Avatar
=S
Old May 27, 2004 | 08:44 AM
JaY-R's Avatar
i'm not gonna flame... looks good for a DIY.. the flames just aren't my style
Old May 27, 2004 | 08:48 AM
-DC2-'s Avatar
http://dohcdx.com/pictures.htm
Old May 27, 2004 | 09:13 AM
hasback*'s Avatar
F*CK THIEVES!
Default Re: (DAGSR511)
coo flames..haha
ive primer a whole car before. den brought it to earl schieb. does that count? lol
Old Jun 4, 2004 | 05:25 PM
m3dia_lab's Avatar
Ok, what is "wet sanding". i'v herd it many times but i dont know what it is?
Can someone please explain.
Old Jun 4, 2004 | 05:26 PM
dawalude's Avatar
Default Re: (m3dia_lab)
wetsanding is just regular sanding, but you make sure there is a layer of water between the sand paper and surface..
Old Jun 4, 2004 | 05:27 PM
dawalude's Avatar
heres my pic finally. painted rear lip, side skirts, and wheels
Old Jun 4, 2004 | 05:37 PM
m3dia_lab's Avatar
Default Re: (dawalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawalude &raquo;</TD></TR><TR><TD CLASS="quote">wetsanding is just regular sanding, but you make sure there is a layer of water between the sand paper and surface.. </TD></TR></TABLE>
how would you keep a layer of water when sanding... lets say the side of the car. do you get a water hose and keep water running over while your sanding?
Old Jun 4, 2004 | 05:43 PM
dawalude's Avatar
not really keeping a layer exactly, just makign sure the surface is well lubricated. you can either use a hose (recommened) or a bucket of water nearby works fine also. as long as you keep the sandpaper clean and wet, and the surface is wet also.
Old Jun 9, 2004 | 10:30 PM
JaY-R's Avatar
can someone list what they do when the PREP a car before it gets painted???
-sand
-wet sand
-primer
-wet sand again
something like that?
Old Jun 9, 2004 | 10:44 PM
al@n
Guest
Posts: n/a
Default Re: (b18bb0y)
what i'd do is sand the car down to bare sheet metal, use some kind of chemical (forgot the name of) to "clean" the metal of contaminants and stuff, spray on a couple coats of primer, wet sand the primer, then spray on the base coats...i never done it before so i dunno if that's the correct way
Old Mar 2, 2007 | 01:52 AM
GTEC913's Avatar
Default Re: (al@n)
good stuff
Old Mar 2, 2007 | 04:20 AM
stas2007's Avatar
Default Re: (GTEC913)
1st try rustolium roll on method aka 50 dollar paintjob
2nd try ..wanted to do something different....the roof is painted by now.yes its spraypainted ,getting clearcoated this or next weekend
???wat do u think?
kingofbattle909
Paint and Body
Mar 3, 2012 07:14 PM
TurboBB2
Paint and Body
12
Nov 11, 2010 03:49 PM
halocore
Paint and Body
Oct 7, 2007 04:34 PM
JaY-R
May 26, 2004 09:41 PM
Integraman06
Jul 3, 2003 04:23 AM
