Vtec problem :(
Old May 26, 2004 | 07:37 PM
B18CJDM ITR's Avatar
Default Vtec problem :(
I have a 95 Integra GSR with very high compression--13:1 and i am running mobil 5W30 oil. I have a unchipped P28 ecu and have about 2500 miles on the motor now. However i have been getting a good vtec cross over out of it ever since i was done breaking my motor in. All of a sudden im not getting any vtec at all. no check engine lights, oil level is good, wiring is good and un cut. I cant not seem to figure out why im not getting vtec and the only thing i can think of is a bad TPS or that my TPS is not getting good readings. I think this because if i beat on the car with vtec or not the idle surges, however if i do not beat on it the idle is fine. Can anyone help me out with this one? thanks
Old May 26, 2004 | 07:47 PM
Frankintegra's Avatar
Default Re: Vtec problem :( (B18CJDM GSR)
Make sure your engine temp is not to high! To high engine temp the VTEC will not work. 13:1 comp will increase you temp! make sure you rad is OK. If it is to high and your rad is OK check your thermosat.
Good luck!
Old May 26, 2004 | 08:03 PM
The HamsterBall's Avatar
Default Re: Vtec problem :( (Frankintegra)
its ok to use 5w30 on such a high compression engine ? i mean 13:1 is kinda crazy.
Old May 26, 2004 | 08:18 PM
dunkd's Avatar
13:1 wowow someone has been trying to play sleeper...
Old May 26, 2004 | 11:31 PM
alfaaay's Avatar
Default Re: Vtec problem :( (The HamsterBall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The HamsterBall &raquo;</TD></TR><TR><TD CLASS="quote">its ok to use 5w30 on such a high compression engine ? i mean 13:1 is kinda crazy.</TD></TR></TABLE>
So is a stock p28. That's a civic ECU right? Runs waaay lean? ...with 13.1 compression
Old May 27, 2004 | 03:16 AM
Default Re: Vtec problem :( (alfaaay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">13:1 wowow someone has been trying to play sleeper...</TD></TR></TABLE>
SHHH
and with that ECU i am running really really lean.....i got a VAFC to change that but its not hooked up and im in the search for an OBD1 P72---GSR ecu
And the radiator is brand new from a 99 Integra so thats an aluminum one not steel.....
Old Jun 6, 2004 | 08:48 AM
bump
Old Jun 6, 2004 | 10:12 AM
dunkd's Avatar
wierd.
Old Jun 6, 2004 | 12:35 PM
Default Re: (dunkd)
werd to i need vtec
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
egcoupeSI
Mar 22, 2008 06:50 AM
1JDMDOMINICAN
Mar 20, 2007 02:03 PM
venger
Jul 6, 2005 11:10 AM
lilxvtecxpwr
Jan 18, 2003 08:06 PM
