h22
Old May 26, 2004 | 06:54 PM
accordracer789's Avatar
Default h22
is the h22 the best way to go with a motor swap?
Old May 26, 2004 | 07:58 PM
secksiman19's Avatar
Default Re: h22 (accordracer789)
no. get an h29.5. those are so frickin awesome. search
i need more info to answer your question...h22s are good for heavy beasts like accords, will generally out you at a low 15 with a manny. they almost sneak right in, one of the mounts has to be ground down a bit. what year is your car
Old May 26, 2004 | 11:37 PM
FatJoe's Avatar
Default Re: h22 (secksiman19)
are flies attracted to ****?
Old May 27, 2004 | 12:25 AM
matix's Avatar
yea in a hatch. Otherwise dont expect to be fast unless you got the chedda.
Old May 27, 2004 | 08:53 AM
patastinky's Avatar
Default Re: (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">yea in a hatch. Otherwise dont expect to be fast unless you got the chedda.</TD></TR></TABLE>
i got a mongoose,
Old May 27, 2004 | 09:05 AM
The_Todd's Avatar
Farts in the shower
Instead of people telling you to search I will help you out...
First off the search tool is a great resource and try that before posting your question
The h22 is one of the most common swaps due to its larger displacement, DOHC vtec and its near simple direct swap. Other things people do is keep their f22 (if its got low miles and or has good compression/leak down tests) and boost it. The f series engine is very well built and can take 6-8psi daily w/o mods and will yield a little more than the h22.
Check out the basic guide at the top of the forum, it has a lot of "commonly" asked questions.
Welcome to h-t
miguel_aka_timon
Sep 16, 2007 09:52 PM
h22inahatch
Aug 14, 2005 12:06 PM
russian_accord
Apr 20, 2005 01:00 PM
jusfuknpounum
Mar 31, 2004 07:53 PM
TalontedTSi08
May 18, 2003 11:19 AM
