Will a b-series ac compressor fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">I tried searching but couldnt find a solid answer, I have a b-series AC comp. and bracket and was wondering if it would work with my swap in my crx</TD></TR></TABLE>
What motor do you have in the crx now? There is a bracket that allows you to use your stock compressor with a B-series swap.
It had a d15b2 in it, I know about the del sol and hcp/hasport brackets but was wondering if this stuff will fit with the ls in because I have it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">It had a d15b2 in it, I know about the del sol and hcp/hasport brackets but was wondering if this stuff will fit with the ls in because I have it.</TD></TR></TABLE>
A friend of mine kept his AC when we installed his B16a in his crx. His stock compressor fit fine with the bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">Stock meaning the one that was in the CRX?</TD></TR></TABLE>
Yes.
Yes.
interesting. thanks for the info but my original question still stands, will the b-series compressor fit in the crx on an LS engine (clearance-wise and concerning the stock ac lines).
i was told that the b series compressor wouldn't work unless you ran new piping? i think you have to use the stock d series compressor with the Ha$port or modify a del sol bracket. but i could be wrong.
dE.fUsEd
Jul 7, 2007 09:56 AM
1.8
12
Dec 18, 2004 06:36 PM
