JDM ITR Headlight (HID) Questions
Does anyone have any suggestions of how to wire the headlights? I was also wondering what type of bulb will fit the low beam lights (the bulb that runs of the HID ballast. For some reason the passenger side low beam flickers and buzzes for a second and shuts off. i dont know if it is the bulb. ANY SUGGESTIONS WOUKD BE GREAT.
to my knowledge if the bulb flickers its not getting enough voltage. and your grounding may be wrong. are you just testing the hid out or is it already wired?
Carlo
Carlo
The bulbs required are D2S. Switch the ballasts and see if the problem follows the ballast (ballast problem) or if it stays on the same side (wiring problem).
please post the threads then... I'm looking for it as well.
only article I've found somewhat helpful is this one
http://tech.wiredspeed.com/jdm_front.asp
anymore with diagrams etc?
