Signals Don't Work
My signals aren't working in my 90 Civic Si Hatch. I have no signals, no hazards, no tach, no gas guage (I think). My check engine light is on. I bought the car off a guy that tried to do a CRX dash swap. If I leave the car running for a while the blinker relay starts smoking (Gets really hot and has a six pin connector). I do have a plug that I can't find a home for though. It is a 4 pin connector (female) and has 2 white wires w/ green stripe, a yellow wire with red stripe, a white wire with blue stripe and a black wire.
Sorry for the novel but I've already changed the cluster, the blinker relay and I've added a relay that I was missing. I just would like to know if I'm missing something. I unwrapped all of the wires going to that cluster and anly found one broken wire but the problem still persists.
Thanks in advance for the help. Sorry for the length but I wanted to be thorough.
Ahh i been there, i had that plm before all there is either ur fuses or you might be missing one of your ground wire hook up so go out there and check it up agian and there is should be about 3 ground wires
FortunateFool.
Audio / Security / Video
Dec 14, 2007 10:46 AM
deucedeuceEK
Jan 15, 2006 07:40 PM
