is it necessary to removal the tie rod when swaping axle?
Old May 26, 2004 | 12:13 PM
david90's Avatar
Default is it necessary to removal the tie rod when swaping axle?
Old May 26, 2004 | 10:23 PM
jlv55's Avatar
Default Re: is it necessary to removal the tie rod when swaping axle? (david90)
pshhh, yeah
Old May 27, 2004 | 03:13 AM
Chiovnidca's Avatar
No
Old May 27, 2004 | 06:54 PM
jlv55's Avatar
Default Re: is it necessary to removal the tie rod when swaping axle? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">No</TD></TR></TABLE>
you reccomend not removing the tie rod end when removing axles? i guess it might not be necessary, but its also not necessary to remove your AEM intake while pulling your engine either.
Old May 27, 2004 | 07:14 PM
machine4321's Avatar
why would remove it when you really dont have too ...
lower ball joint has to com eout then it pivots nicly out of the way when attached to the tie rod
Old May 28, 2004 | 09:25 AM
Chiovnidca's Avatar
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klutch44 &raquo;</TD></TR><TR><TD CLASS="quote">
you reccomend not removing the tie rod end when removing axles? </TD></TR></TABLE>
I don't disconnect them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">why would remove it when you really dont have too ...
Old Jun 16, 2004 | 02:54 PM
RCautoworks's Avatar
Yep or you could just unbolt the control arm from the frame and not even worry about those ball joints.
Old Jun 16, 2004 | 03:27 PM
jlv55's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Yep or you could just unbolt the control arm from the frame and not even worry about those ball joints.</TD></TR></TABLE>
i did that before.
Old Jun 16, 2004 | 04:55 PM
JDM.Accord's Avatar
Default Re: (Chiovnidca)
I don't disconnect them. </TD></TR></TABLE>
Yeah you don't really need to. I've done two axles without disconnecting either time.
Old Jun 21, 2004 | 11:10 PM
patastinky's Avatar
Default Re: (JDMAccord2nr)
if you remove the lower control arm from the crossmember.. You'll need to remove the (2) radius rod bolts too Not to mentoin the fork that hold the shock to the lower control are to0
Hanmin
28
Mar 9, 2008 01:47 AM
Honda_Eq
10
Jan 25, 2008 11:38 AM
SoOHiGH
Jul 13, 2005 05:49 PM
xerox445
Feb 9, 2004 09:54 AM
wm5holla
Sep 16, 2003 05:28 PM
