Turbo & fuel related. True/False?
I have a h22a
1. Before I install my turbo can I just install my walbro (255lb/h) fuel pump or would in push to much fuel for a the stock motor?
2. Same with the 440 DSM injectors, I'm certain the car will run very rich if I installed these before the turbo goes in. Is this true?
3. Can I fix these two problems on a stock motor with a FPR?
4. Can I run a 7psi + intercooled t3/04 on my p72 or p13 ECU without any VAFC or MSD for now?
1)you'll probably be ok
2) yes, you'll run rich
3)no, a fpr will not compensate for that much stuff and still be able to richen the mixture up on the top end enough.
4)You could probably run w/o the msd. But the lack of tuning will detonate the motor. Or just burn it up.
nota-eg
Jun 17, 2005 07:40 AM
