How to determine Injectors??
Old Nov 9, 2001 | 07:24 AM
REDBARON's Avatar
Default How to determine Injectors??
Hey guys, just wanted to know if there is a way to determine what kind of injectors one has? Like some kind of lettering or something. I want to know because I have a 90 civic hb with a 95 sohc vtec, and I'm wanting to know what kind of injectors are being used with the CRX si Ecu. I just bought this car, and I'm trying to find out as much info as possible about what makes this swap work. Thanks guys.
Old Nov 9, 2001 | 07:58 AM
markedOO1's Avatar
Default Re: How to determine Injectors?? (VTECHatch)
...if you're running the stock ecu, then I'm sure they're probably the stock injectors b/c the OBD1 and OBD2 injectors are saturation and the OBD0 are peak/hold..... dont know about desgnations on the injectors though.
Old Nov 9, 2001 | 10:27 AM
REDBARON's Avatar
Default Re: How to determine Injectors?? (marked001)
Ok let me get this right? If I'm using the stock CRX si ECU, then I SHOULD be running, the same injectors and distributor. Am I right?
Old Nov 9, 2001 | 10:42 AM
markedOO1's Avatar
exactly, the newer (obd1) distributor and injectors will not work w/o the OBD1 distribuotor (p28).
Old Nov 9, 2001 | 12:52 PM
REDBARON's Avatar
Ok. I was wondering about that. Since my distributor is mounted on the head pretty weird.
bigek
Jul 7, 2018 04:29 PM
Kdx
Jul 7, 2018 09:10 AM
whagkangmakulet
Dec 24, 2002 07:21 AM
markedOO1
Nov 26, 2001 07:50 AM
