where can i find the iab solenoid valve and the the knock sensor
Old May 26, 2004 | 07:37 AM
racingant's Avatar
Default where can i find the iab solenoid valve and the the knock sensor
I have a single v-tec motor and i'm trying to run v-tec but i need to know where the iab solenoid vavle is and where the knock sensor is on my single v-tec motor is
Old May 26, 2004 | 07:42 AM
APEX CRX's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (racingant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">I have a single v-tec motor and i'm trying to run v-tec but i need to know where the iab solenoid vavle is and where the knock sensor is on my single v-tec motor is </TD></TR></TABLE>
HUH?
Old May 26, 2004 | 07:53 AM
racingant's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (APEX CRX)
bump
Old May 28, 2004 | 09:38 PM
racingant's Avatar
bump
Old May 28, 2004 | 10:12 PM
shaddr3's Avatar
knock sensor should be on the left side of the block
Old May 28, 2004 | 11:09 PM
Keebler's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (shaddr3)
If i remember correctly its near the timing belt, but im not absolutely certain...Id need a repair manual The knock sensor may also be near the oil filter, but i may also be confusing this with a mitsu engine
Sorry, damn guess its time for me to buy a chiltons guide :D
Old May 29, 2004 | 04:50 PM
al3e's Avatar
BUMP i need the same thing. i am getting the 23 code. knock sensor.. donno where its at. or how to fix it....
Old May 29, 2004 | 09:19 PM
racingant's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (al3e)
i need help to find out where the knock senser and the iab solenoid valve is
Old May 29, 2004 | 10:30 PM
Rywire's Avatar
Iab is for a gsr engine, intake air bypass. The knock sensor is above the oil filter. Ryan
Old May 29, 2004 | 10:53 PM
y49crxsi's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (droppedcrxsi)
I didnt think obd0 had a knock sensor, niether did the 92-95 d16z6's, but my 2000 y8 one had one, by the oil filter. What motor do you have???? And why do you need teh knock sensor, unless your obd1, which if your running p28, i dont think you need.
Old Jun 12, 2004 | 06:14 AM
racingant's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (y49crxsi)
does the single vtec motor have a knock sensor if so where is it
does the single vtec motor have a iab valve if so where is it and do i have to run wire to them when i'm running vtec
Old Jun 12, 2004 | 08:38 AM
Rywire's Avatar
Are you asking this because you are going obd1, and the conversion harness has these labeled? If so just leave them alone, you dont need them, Ryan
Old Jun 12, 2004 | 09:13 AM
kamikazeCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote"> The knock sensor is above the oil filter. Ryan</TD></TR></TABLE>
It's right there, you can't miss it, right above the oil filter. But you don't need it unless you're running OBD1.
Old Jun 13, 2004 | 10:55 PM
racingant's Avatar
Default Re: where can i find the iab solenoid valve and the the knock sensor (kamikazeCRX)
i'm trying to do obd0-obd1 is there a knock sensor or a iab valve on the sinlge vtec motor do i have to run wire to them or not
Old Jun 14, 2004 | 09:08 PM
racingant's Avatar
bump
Old Jun 15, 2004 | 05:00 AM
boomslang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant &raquo;</TD></TR><TR><TD CLASS="quote">i'm trying to do obd0-obd1 is there a knock sensor or a iab valve on the sinlge vtec motor do i have to run wire to them or not</TD></TR></TABLE>
You do not need to run them.
SingleCamin
May 19, 2009 08:23 AM
carraway99
Feb 17, 2005 10:29 PM
codeh22a4
Apr 8, 2004 12:51 AM
coyote
11
Sep 11, 2003 09:24 AM
yellowmonkeyboy
Jun 29, 2003 02:35 PM
