automatic ecu with a 5spd car
Old May 26, 2004 | 05:48 AM
wpgcivic's Avatar
Default automatic ecu with a 5spd car
what will this do? i found out that my b16 ecu is a automatic and my car is 5 spd...
i get no codes besides knock(not hooked up) also i am trying to figure out my erratic idle, think this might be the problem??
Old May 26, 2004 | 05:52 AM
Kal's Avatar
Kal
Default Re: automatic ecu with a 5spd car (wpgcivic)
i doubt it. auto ecu wouldn't affect idle, it just affects driveability
Old May 26, 2004 | 06:09 AM
boosted15's Avatar
Default Re: automatic ecu with a 5spd car (Kal)
I belive your idle is going up and down. The reason for this is that the auto ecu idle is set at a higher rpm, basically for the trans. This will affect your idle and also performance. There is a way to fix this problem with your idle. Go to http://www.hondata.com and it will show you how to convert auto ecu to manual. It should be in the installation guide for the s200. You should be able to fix your problem easily. Good luck!
Old May 26, 2004 | 06:24 AM
wpgcivic's Avatar
Default Re: automatic ecu with a 5spd car (boosted15)
i am going to try my buddys ecu tonight and see if that is my idle problem and hopefully it will also be faster than before...it better work or else i am outta idaes for what my idle problem is
Old May 27, 2004 | 04:47 AM
wpgcivic's Avatar
got a manual b16 ecu and the idle problem is gone and it works like a glove
immalooser
Feb 18, 2009 05:23 AM
rice is nice
Apr 1, 2006 12:44 PM
majek
Jul 17, 2005 05:10 AM
LSpimpTEC
Apr 28, 2003 11:29 PM
