auto ecu on a manual car
Old May 26, 2004 | 05:48 AM
wpgcivic's Avatar
Default auto ecu on a manual car
what will this do? i found out that my b16 ecu is a automatic and my car is 5 spd...
i get no codes besides knock(not hooked up) also i am trying to figure out my erratic idle, think this might be the problem??
Old May 26, 2004 | 07:21 AM
-slow ej-'s Avatar
Default Re: auto ecu on a manual car (wpgcivic)
i had the same thing on my car a month ago..diff motor...d16z6 with a auto p28 then i just searched on h-t and changed it to a 5 spd till this day runs fine
Old May 26, 2004 | 11:24 AM
wpgcivic's Avatar
so it was auto but you got it chipped to 5 spd? how did it run when it was auto
Old May 26, 2004 | 12:04 PM
crxgator's Avatar
Default Re: (wpgcivic)
it will run fine as an auto ecu, you will just will have about a 7500 rpm fuel cut off though...
Old May 26, 2004 | 12:50 PM
Mr_CRX's Avatar
Default Re: (crxgator)
I believe on http://www.pgmfi.org there are directions on how to change an auto ECU to manual.
My pr3 ecu was an auto, but it got changed to manual by the previous owner. Sold it to a friend with an ls/vtec and it runs fine up to 8k.
Old May 26, 2004 | 02:01 PM
R6Boy69's Avatar
if you want to send me your ecu i can convert it for you... pm me if you are interested... I'm in Ontario...
Old May 27, 2004 | 04:47 AM
wpgcivic's Avatar
hey guys got a manual ecu and the idle prob is gone and it runs great
Old May 27, 2004 | 06:22 AM
91civicDXdude's Avatar
okay give me the auto ECU :D
Old May 27, 2004 | 09:55 AM
wpgcivic's Avatar
Default Re: (91civicDXdude)
lol actually i found a guy to trade me str8 up for a manual one so i am all happy
Old May 27, 2004 | 10:24 AM
chambersef8's Avatar
same problem, (auto pr3 with a manuel) does the auto pr3 have weaker timing and fuel maps or is the only difference the fuel cutoff?
Old May 27, 2004 | 11:39 AM
wpgcivic's Avatar
the idle was erratic and the red line was quite lower
Old May 27, 2004 | 11:58 AM
my idle is fine, I did notice the 7500 fuel cut though. So is that the only difference, or am I missing out on some performance also???
Old May 27, 2004 | 12:20 PM
wpgcivic's Avatar
i definitly noticed the performance difference
zenmark84
Apr 22, 2019 08:11 AM
suspirocrx
Mar 8, 2010 03:13 PM
tturbocivic0618
13
Apr 15, 2008 01:40 PM
turboex
Apr 12, 2002 10:43 PM
