tranny install problems?
Hi.
I just installed a new ls tranny in my 94 integra and it doesn't seem to want to grab. I can start it in gear without jerking the car, and the car doesn't die in 1st gear. 1st and second gear does nothing, in 3rd-5th if I press on the gas pedal my speed goes up with the rpm while the car isn't going anywhere, and in reverse it makes a wired low noise.
Pior to installing the ls tranny I had a gsr tranny with bad snchro in 2nd, 3rd and 5th so I opted for a better condition tranny in the LS tranny w/no grind. It was driving fine, except for the gear grinds.
I didn't touch the clutch assebly at all, just took the gsr tranny out and pop the ls in. So I'm at a lost... seems like the clutch is out of place for something.
Any help would be appreciated.
Im kinda lost....
You say the speed goes up with the RPMs; but the car isnt going anywhere?
My friend had his differential go and he said some of the similar things; but your car is moving in some gears?
Maybe post a good reply so we can get a better idea. It sounds very interesting.
Check your drive shafts, one of them is not all of the way in, If when you installed them you do not get them to snap in they can pop out a slight bit and you will not be able to go anywhere, since the speed sensor is drivin off of the diffy it will still show speed with no movement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itaintegra52 »</TD></TR><TR><TD CLASS="quote">Check your drive shafts, one of them is not all of the way in, If when you installed them you do not get them to snap in they can pop out a slight bit and you will not be able to go anywhere, since the speed sensor is drivin off of the diffy it will still show speed with no movement.</TD></TR></TABLE>
