transmission
hey guys i got a ? for all ya honda techs in here
today in the shop i just finished a tranny swap on a 1994 honda accrd lx automatic tranny.. evrything went fine except that on the dash it says that it in parking light is red/ but it flashing the D light green if any of you can help me on this it would be grately aprciated.. need answers asap
thx josue
thx josue
First pull the error code. Flashing "D" light is the tranny's version of a check-engine light. You check it the same way. I don't have a '94 but I guess the wires you want to jumper are located somewhere around the console or ashtray? (Searching would be a good thing...)
Jumper that plug & turn on the key. Your check-engine light may or may not flash out a code, but your 'D' light will flash out it's own code.
edit...
I only know a couple tranny codes from my '98, and I'm not sure whether they're the same for different years, like CEL codes. Your best place to look would be a Helm book for your car.
Modified by JimBlake at 4:49 PM 5/26/2004
edit...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Flashing "D" light is the tranny's version of a check-engine light.
Do you have the list of error codes for tranny D light ?
The service check conector is under the dash on the passenger side. Just short the 2 wire conector, turn the ignition to on and watch the indicator on the dash (D4) it will give you a codejust like engine check light, beware some PGM-FI problems will also make the D4 light flash . There are 15 code and i have them, so tell me what code is and I'll help you.
Make sure all conectors are well atach, reset the tranny by disconnecting the battery ( is the easy way) and then check again for the codes.
thx for all the replies guys i didn't figure what the problem was but i check the check engine light and i was just a coolant Temp sensor as for the tranny code it only flashed once i check all data and it really didn't tell me anything. it just said to disconect the back up for for 10 sec.. when i put it back the code was gone from the tranny..
thx josue
thx josue
deanwashere
Jul 25, 2018 04:28 AM
jdmek2277
Oct 6, 2008 09:59 AM
